zed audio leviathan lll
e68ed843.jpgbb8b910c.jpgamp is nib, only opened for pics , this came directly form zed and i had steve internally jump the rca so i can only use 2 rca and run the channels active , this is just a jumper pin inside the amp and literally can be removed in 5 minutes, i prefer internal jumper rather than a bunch of rca on the outside. amp arrived yesterday and is legit the newest version lll. price is 725 shipped con u.s. paypal preferd and no trades. refrences , 55 positive feedback between carudio and caco (carudio cal) caco (caloriu)
specs
Rated power is 190 watts x 6 into 4 ohm or 300w x 6 into 2 ohm.
Bridged power is 380w x 3 into 8 ohm or 600w x 3 into 4 ohm.
The 3 pairs of channels are independently bridgeable.
Two, four or six input configuration.
Channels 1+2 feature a 24dB per octave Linkwitz Riley High crossover.
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass or Low Pass from channels 5+6.
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass or Low Pass from channels 5+6. .
Channels 5+6 feature feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 5+6 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
The High Pass crossover doubles as a subsonic filter as it is able to respond down to 10Hz.
No trades even for batts??
