Volt meter
Yeah, I ran a relay to make a switchable ground connection from the amp to the voltage readout. This way, I'm monitoring the voltage at the amp, but it's a 12V switchable system (off with the ignition).
Edit: Relay was $5 from Advance
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
So... You used to wire up alarms for a dealership but couldnt figure this out and made a thread about it?
Strange.
Strange.
It's not that I couldn't figure it out. I was trying to see if there was another, easier way. I didn't feel like wiring a relay into the setup, but I also didn't wish to leave the 2-wire setup turned on all the time.
This car is a 2011, so a switch wasn't really even an option. I'm not trying to do any permanent mods until it is out of warranty.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
You could get brave and just pull the source wire on one of your fuses and run a wire to the amp in back. Then you would have a switched volt meter and still be able to use whatever else is on the fuse. But relay is the "kiss" method.
Here's a few pics, sorry for the quality, was on the cell.
In the dark figuring out the wiring...
Snapped this one a few min ago, everything working perfectly.
Glare makes it a little hard to see, especially in direct sunlight.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
  • Who's Online   0 Members, 0 Anonymous, 1530 Guests (See full list)
