I need help with designing a ported subwoofer box for two sundown sa-12 4 ohm's. I have a skar sk-1500 amp powering them. The max dimensions for the box is Height- 22 in, Width- 42 in, Depth 13 in. The recommended settings is 4 ft^3 total and tuned at 35-37 hz. I need a round port. Thanks a lot!
Here is a suggestion, vehicle model found in an older thread:
Enclosure Specifications:
Fb = 35 Hz
Vb = 4 ft^3
External Height = 21 in
External Width = 36 in
External Depth = 13 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 36 x 13
Left & Right Sides = 11 1/2 x 19 1/2
Front & Back = 36 x 19 1/2
Port Quantity and Dimensions:
Number of Ports = 1
Pipe Port Diameter = 6
Pipe Port Length = 11 1/8
Assembly guide (generic dimensions):
I would add that although a 6" flared aero can work a slot across the bottom could optimize port area of your box and may be a better alternative.
  • Who's Online   0 Members, 0 Anonymous, 993 Guests (See full list)
