mrd6 Posted September 17, 2012 Report Posted September 17, 2012 So for those of you who have built walls starting with a steel frame for bracing, what method have you found is best for securing the wood to the inside of the frame? Some combination of metal screws and a construction adhesive? What have you guys done? My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
HHR Ed Posted September 17, 2012 Report Posted September 17, 2012 lay down a bead of construction adhesive. Lay down sheets of wood. Mark and drill countersink holes and pre-drill into steel. Use metal screws to secure wood to steel. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
fox_racin4 Posted September 17, 2012 Report Posted September 17, 2012 self tapping screws unless you use like.. sheet metal.. normal screws will go threw your cars sheet metal no problems too.. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
mrd6 Posted September 17, 2012 Author Report Posted September 17, 2012 sounds good, thanks guys My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
