barney91 Posted October 18, 2012 Report Posted October 18, 2012 For my front stage I was thinking of running 2 RF pro 8s but I havnt checked if they will fit What are the dimensions of the box it seems kind short, because most of the builds I've seen have the box to the height of the rear seats Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
97SSBlazer Posted October 18, 2012 Author Report Posted October 18, 2012 For my front stage I was thinking of running 2 RF pro 8s but I havnt checked if they will fit What are the dimensions of the box it seems kind short, because most of the builds I've seen have the box to the height of the rear seats you could probably make an 8" fit BUT you would have to make a pod for it. The box is ~20^3 ft lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
barney91 Posted October 18, 2012 Report Posted October 18, 2012 That's bigger then I thought. Well I really like the build specially because your running all rockford gear, keep us posted with updates Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
97SSBlazer Posted October 24, 2012 Author Report Posted October 24, 2012 Well I got a lot done today, Fiberglassed my kicks, Finished my console, installed cooling fans, added another pair of T1's to my front doors. The RF PP4-T Tweeter is LOUD. I only have ~50 watts RMS to each speaker, So when I get my new 4 channel it will be even louder The insert in the center console will have a nice sized oval cut out in it so you can see the T2500. lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
barney91 Posted October 24, 2012 Report Posted October 24, 2012 That looks dope I like where you put the tweeters Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
tank03hoe Posted October 24, 2012 Report Posted October 24, 2012 nice build! play with the box a lil bit and how low do you have the ohm load on the amp im only using 3k in my hoe also wiring an batts make a huge difference lets see this thing get louder! american bass 1100.1 2 hertz hdp4 m&h amps hertz xls audison voice mids and highs 4 fi hybrid subs 1 xs power g31 batt and 6 banks of maxwell caps big 3 mechman 270 singer 350 and another singer 300 amp alts 7 runs of 4/0 TEAM bass drop meca s4 2011 153.7 db at headrest 4 15s
97SSBlazer Posted October 24, 2012 Author Report Posted October 24, 2012 That looks dope I like where you put the tweeters Thanks man, It was an easy solution nice build! play with the box a lil bit and how low do you have the ohm load on the amp im only using 3k in my hoe also wiring an batts make a huge difference lets see this thing get louder! Since I got the alt, It is MUCH louder, I havent metered it again and I dont really care what the laptop says. I don't build my cars for a laptop, I build them for demos to customers and other people. I am at 1 Ohm nominal. I thought 147's+ on Music @ 3K was pretty good.... lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
barney91 Posted October 24, 2012 Report Posted October 24, 2012 How much air are you moving, can you do a hair trick or is it tuned to hi for that Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
97SSBlazer Posted October 24, 2012 Author Report Posted October 24, 2012 I dont know if it will do a hair trick :/. There is a lot of air space in the truck so I dont know if I have enough power, Its moving some air though, I'll have to try it and see... lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz. -= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash Subs: 2 T1 12's Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:) 2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/ 2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/
tank03hoe Posted October 24, 2012 Report Posted October 24, 2012 That looks dope I like where you put the tweeters Thanks man, It was an easy solution nice build! play with the box a lil bit and how low do you have the ohm load on the amp im only using 3k in my hoe also wiring an batts make a huge difference lets see this thing get louder! Since I got the alt, It is MUCH louder, I havent metered it again and I dont really care what the laptop says. I don't build my cars for a laptop, I build them for demos to customers and other people. I am at 1 Ohm nominal. I thought 147's+ on Music @ 3K was pretty good.... ahhh thats koo too i like giving demos also i compeat though so i have to rely on the laptop but i make shure i have the best of both worlds also trying a lil sq out american bass 1100.1 2 hertz hdp4 m&h amps hertz xls audison voice mids and highs 4 fi hybrid subs 1 xs power g31 batt and 6 banks of maxwell caps big 3 mechman 270 singer 350 and another singer 300 amp alts 7 runs of 4/0 TEAM bass drop meca s4 2011 153.7 db at headrest 4 15s
