Sagaie Posted September 18, 2012 Author Report Posted September 18, 2012 Turns out my boot is actually 94cm wide by 74cm long by 38cm high
Joe X Posted September 18, 2012 Report Posted September 18, 2012 Ok here is a suggestion in metric units, note that I have used 19mm wood thickness which should be the nearest metric equivalent to 3/4 in standard wood thickness. Enclosure Specifications: Fb = 34.5 Hz Vb = 2.7 ft^3 External Height = 35.75 cm External Width = 80 cm External Depth = 51 cm Port Width = 9.5 cm Cut Sheet List: * All Dimensions in Centimeters. * Wood Thickness is 1.9 for all Parts. External Enclosure Parts: Front & Back = 80 x 35.75 Left & Right Sides = 47.2 x 31.95 Top & Bottom = 80 x 47.2 L Port Internal Assembly Parts: Front to Back = 37.7 x 31.95 Extension = 30 x 31.95 Assembly guide (generic dimensions): If you want anything changed or have any questions let me know.
Sagaie Posted September 18, 2012 Author Report Posted September 18, 2012 Thank you ! I will get working on it the weekend and let you know how it goes My dad works with wood so im sure it wont be too hard if i get his help Much appreciated Edit: also is it possible to get a top view of the box ?thanks !
