Digital Designs M3 amp question
GSanders17
I just recently purchased an older DD M3 amp and it is replacing a Sundown Saz-1500d. I am running one DD 3512 sc. The sundown was a good bit more impressive than this M3. Something doesn't seem right about that. Both were tuned with the dd-1 so I'm alittle lost on what is wrong. Nothing has changed with the setup so I was wondering what might be wrong. I was running a stock alt and kinetik hc 1400 with the sundown and same with the M3. I know I need to upgrade the alt and battery but thought the M3 would atleast be equivalent to the 1500 for time being.
Trust me, the M3 it´s a badass amplifier, i´ve clamped over 3K from those things, yes your electrical is way to small for that amplifier and that might be one of the reasons you don´t see more power, remember, you need power to produce power!! Also, have you tried giving it a little bit more gain? sometimes o-scopes are like that, a little bit of clipping get you way louder....
i had the same problem when switching from my soundstream 1300 to my DD m2. i was like "why the hell is it quieter?" the only thing that helped was when using the dd-1 it tells you to turn the amps LPF frequency all the way up. well i just turned the LPF frequency up to where i like it, and then went through the normal dd-1 procedure. i think doing it this way should be fine because my amps clip light comes on at about the same time the dd-1 shows distortion.
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
  • 1 month later...
  • Who's Online   0 Members, 0 Anonymous, 1144 Guests (See full list)
