FrontierGello Posted September 23, 2012 Report Share Posted September 23, 2012 Need help on ported enclosure design. I have 2 Re Sxx 15 d2 subs running in 2 Re Xt4000de amps 1 ohm load. maximum dimensions are 32" height 42" width and 22" depth. Can someone help me with a design? tuning to 29 to 34 Hz. Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
Joe X Posted September 23, 2012 Report Share Posted September 23, 2012 Which would be your vehicle model? and what type of music you listen? Link to comment Share on other sites More sharing options...
FrontierGello Posted September 24, 2012 Author Report Share Posted September 24, 2012 Which would be your vehicle model? and what type of music you listen? its a 1999 nissan frontier gonna place the subs inside the cab and take off the rear seats. i listen to house and hip hop music Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
Joe X Posted September 24, 2012 Report Share Posted September 24, 2012 Ok here is a suggestion: Enclosure Specifications: Fb = 34 Hz Vb = 7.75 ft^3 External Height = 26.75 in External Width = 36.5 in External Depth = 22 in Port Width = 20 1/2 in Port Height = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 36 1/2 x 22 Left & Right Sides = Side 1 = 19 x 20 1/2 Side 2 = 24 1/2 x 20 1/2 Front & Back = 36 1/2 x 24 1/2 L Port Internal Assembly Parts: Side to Side = 24 1/4 x 20 1/2 This box requires 5 1/2" free airspace in front of the side port.Let me know any questions. Link to comment Share on other sites More sharing options...
FrontierGello Posted September 24, 2012 Author Report Share Posted September 24, 2012 Ok here is a suggestion: Enclosure Specifications: Fb = 34 Hz Vb = 7.75 ft^3 External Height = 26.75 in External Width = 36.5 in External Depth = 22 in Port Width = 20 1/2 in Port Height = 5 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 36 1/2 x 22 Left & Right Sides = Side 1 = 19 x 20 1/2 Side 2 = 24 1/2 x 20 1/2 Front & Back = 36 1/2 x 24 1/2 L Port Internal Assembly Parts: Side to Side = 24 1/4 x 20 1/2 This box requires 5 1/2" free airspace in front of the side port.Let me know any questions. Thanks for the suggestion but which would be louder? 2 subs in 1 box or 1 sub per box? Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan Link to comment Share on other sites More sharing options...
Joe X Posted September 24, 2012 Report Share Posted September 24, 2012 There is nothing that individual boxes specifically can do to to make you louder, just take up more space, you just have to gain match the amps if not strappable. Link to comment Share on other sites More sharing options...
