CleanSierra Posted September 28, 2012 Report Posted September 28, 2012 Honestly, it's not gonna take much to make CVRs come to life. You need to focus on a properly built box for them FIRST and foremost. Any amp that does 800-1500 will work just fine. Important thing is, when you set the amp, have the gain set properly as well. On a side note(which you probably won't get) make sure the port is on the correct side of the box. If someone tells you to move the port to avoid blowing the subs, you DOOOOO it!!! i told him to move the FUCKING PORT!!!..........lmao like that would of saved his sub riiiiiiiight Moving the port ALWAYS saves subs from a poor design. Just like wiring a Boss amp at .5 ohm is always the best way to get the most power from it! Im not the one you want to try to troll. Just a fyi for you.
cmegorm250 Posted September 28, 2012 Report Posted September 28, 2012 I wouldn't run more than 300 watts to a single CVR.
