LMB audio citroen C2 demo car 16 aa 10s, b2 front end, gladen amps
haha thanks guys might have some more pictures later off to go get high with 15liters of fiberglass resin
Pioneer deh P71000BT, Audiocontrol Epcenter
2x 18" FI BTL neo 2 fully loaded with smd baskets , 5X JBL: gto-837,
4x JBL: GTO-1201.1 Mono Amps, 2x Genesis Profile 4
2x XS POWER D3100 Batteries , ‎155.6dB @31hz off 4,400rms,
70amp alternator
hopfully one more skim and that side is done
rear panels made and worked out the amp layout i can now fit a 7th amp and a 3rd xs 3100d if we need to
time to start getting the box sealed
70amp alternator
time to start fiberglassing now going todo the corners where the car is 1st then im going todo the whole inside of the box
70amp alternator
  • 3 weeks later...
steel bracing on all 8 corners
car is in primer at last
smoothed off the fog lights
3liters of fiberglass and resin mix in the whole top half of door
bus bar finally done might give it a polish when i have time just need need to make perspex box for it now
now this is the reason you dont leave the keys in the car i leave the car is reverse as it has no hand brake.
duncan decided to start the car it shoot back 10ft into 10 of the subs and a wall :\
damage to the car
damage to 1 sub
funny how the subs aint even in the car yet and there destroying it :L
70amp alternator
well cuple more bits been going on car is now ready for paint and the main box is nearly done just a little more steel todo
then cuple coats of fiberglass once thats done i can get the tunnel finished and get it in the car for good and get it fully
sealed up and start running wiring
think we are going to go for the brushed look as not a fan of the bling bling polished look
not sure what the plan for the roof is might wrap it in matt black
hopefully tuesday or wednesday it will be in paint then i can start putting it back together and wont feel like i have so much todo
70amp alternator
