I'm going to try to word this the best I can, because it even confuses me. So on my head unit (pioneer deh-p8300ub) I have 4x22watts rms output for my speakers, 1 for each front speaker, 1. For each back speaker. However, in my car I have 3 sets of speaker locations, 1 in the rear deck (rear), 1 in the front doors (front), and 1 in the dash (dash). After investigating, I found that both the front and dash speakers were running off the head units front power outputs (they were sharing). I recently took both the front and rear speakers off the head unit ad used an external amplifier to power those two sets. Now, here's my question: I am looking to buy an new set of 3.5 inch coaxial speakers for my dash which will be ruunning off the head unit. Will the power they recive be 22 wats rms per speaker since I don't have the front door speakers running through the head unit, or will it still be cut in half to 11 watts rms per speaker because the power from the head unit was split into 2 separate ses of speakers? The reason I ask is because it will determine which speakers I buy.
Hopefully that all made sense, if not just letme know. Thanks in advance!
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Nobody knows?
Subs/Amps: TBD
22 each
in a million, trillion, kabillion years,i would never play that song in my ride. I don't care if its clipped or not LOL. I feel like my nads got clipped after playing this for 15 seconds just to see what it was LOL.
No thanks bro. Not into it.
Alright then my next question is since I don't have any speakers plugged into the rear output of my deck could the power from the rear 2 outputs be transferred to the front speakers output making it 44 watts rms per dash speaker?
Subs/Amps: TBD
Please guys? This is something I have always been curious about and now that I need a new set of speakers I need to know the answer...
Subs/Amps: TBD
how do you propose to give them 44 watts of headunit power at that? You thinking of trying to bridge the channels or something? you are way overthinking this. just because you arent using the outputs the power is not going to magically transfer to the front speakers or anything. It just wont happen
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If the front output form the radio is hooked up to 2 sets (the dash and front doors) totalling 4 speakers. then the output of each channel (L+R) would be split. 11w RMS to each speaker.
If you unhook a set (say the dash), then each front door speaker will get 22w rms. You only lose power if something if drawing, a split is just a connection.
Now what are you asking here? You want to keep the front and rear outputs from your radio separate. They are a different signal. Once you start tying things together like that you cause changes in impedance and your built-in amplifier (in the headunit) will not work. So simply NO, you CANNOT tie together the front and rear channel for a single pair of speakers. You COULD however do the front output on your dash speakers (22w rms each) and the read output on your front door speakers (22w rms each.)
I hope that answered your question. Get a pair of Rockford Fosgate Punch speakers. They will sound great on an aftermarket headunit, just keep the shitty eq's off.
Car: 2011 Ford Taurus SEL / Alt: DC Power 270XP (Will be here 7/17!!!)
Deck: Pioneer AVIC-Z140BH / Amps: (1) DC 5.0k, (1) RF T400-2
Speaks: RF T2652-S 6.5" and RF T1692 6x9"
Subs: (2) DC XLm2 15's / Batts: (2) XS XP3000's
Wiring: Kolossus Fleks Kable 1/0 (2 runs)
I see how you deciphered that, better than I did! The 22w rms rating is per channel. That is the max you can get per channel. A setup with no rear left, no rear right, no front left, but then hooking up a front right will still only give you 22w rms to that front right speaker.
Alright thanks guys, that answers my question, I guess I jus wanted to make sure that the power wouldn't be going up front and making it 44 rms a piece so that I wouldn't blow a pair of speakers in 3 uses. And the rockford punch 3.5s is what I was planning on running. Thanks again guys, guess I was over thinking it lol, sorry...
Subs/Amps: TBD
  • Who's Online   1 Member, 0 Anonymous, 1204 Guests (See full list)
