There is a place to use a line driver. Most cases are with stock headunits that have weak preout voltages. If you have a good aftermarket headunit with a 2v+ preout voltage, then there is no need for a line driver. I just had to use my bench to show the test.
Is there any advantage using a line driver with a aftermarket Head unit 2v preout voltage?
Just not needing as much gain.
