MIKE-2U Posted October 9, 2012 Report Posted October 9, 2012 Any Grand Cherokee owners out on the forums? few questions for ya. how easy is it to run wires ? i want to run 2 positive and 2 negitive to the back and i am wondering the best way to do this. Is there a grommet or something i can go in through. Plan to run the wires inside frame rails. Unless i can get all that wire under the carpet. suggestions ? anything else to look out for when installing audio into this vehicle ? mine is a 06 Grand Cherokee Laredo 4.7 thankx 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
DylanBunch Posted October 9, 2012 Report Posted October 9, 2012 Any Grand Cherokee owners out on the forums? few questions for ya. how easy is it to run wires ? i want to run 2 positive and 2 negitive to the back and i am wondering the best way to do this. Is there a grommet or something i can go in through. Plan to run the wires inside frame rails. Unless i can get all that wire under the carpet. suggestions ? anything else to look out for when installing audio into this vehicle ? mine is a 06 Grand Cherokee Laredo 4.7 thankx 1 run under the the frame and one run under the carpet would do fine but i wouldnt do both runs under just the rail or just the carpet, too noticable 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
MIKE-2U Posted October 9, 2012 Author Report Posted October 9, 2012 Any Grand Cherokee owners out on the forums? few questions for ya. how easy is it to run wires ? i want to run 2 positive and 2 negitive to the back and i am wondering the best way to do this. Is there a grommet or something i can go in through. Plan to run the wires inside frame rails. Unless i can get all that wire under the carpet. suggestions ? anything else to look out for when installing audio into this vehicle ? mine is a 06 Grand Cherokee Laredo 4.7 thankx 1 run under the the frame and one run under the carpet would do fine but i wouldnt do both runs under just the rail or just the carpet, too noticable So both positive runs under carpet, and both negitive under the vehicle ? is there a hole or something i can use so i dont have to drill ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
94jettameowpsst Posted October 9, 2012 Report Posted October 9, 2012 Any Grand Cherokee owners out on the forums? few questions for ya. how easy is it to run wires ? i want to run 2 positive and 2 negitive to the back and i am wondering the best way to do this. Is there a grommet or something i can go in through. Plan to run the wires inside frame rails. Unless i can get all that wire under the carpet. suggestions ? anything else to look out for when installing audio into this vehicle ? mine is a 06 Grand Cherokee Laredo 4.7 thankx 1 run under the the frame and one run under the carpet would do fine but i wouldnt do both runs under just the rail or just the carpet, too noticable So both positive runs under carpet, and both negitive under the vehicle ? is there a hole or something i can use so i dont have to drill ? I dont have a grand, but i have a 98 xj. I ran 0 gauge from the front battery through a hole i drilled in the firewall under the carpet under the center console and under my back seat and all my batteries are in the back behind the seat. The grounds I ran and attached to the frame through one of the rubber gromets under the back seat. 150.1 @ 38hz142.3 @ 20hz (windows down)Only 2 batteries
JesseyMclame Posted October 10, 2012 Report Posted October 10, 2012 I had a zj and drilled a hole on the lower passenger side. Current setup in my 96 Hoe Hu - Pioneer DEH-80prs. Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets) Batts - 4 91ah rear batts, 50ah batt up front. Subs - 2 Crossfire XSv2 18's Alt - Singer 330A Front stage - Random JL & Eclipse mids, Eclipse tweets
DylanBunch Posted October 10, 2012 Report Posted October 10, 2012 go through the fire wall like that one guy said. I did that on the driver side then i have the battery wire going under the rail. whether you do all positive one way all negative the other or whatever which way is up to you 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
MRLOWOFFSET Posted November 16, 2012 Report Posted November 16, 2012 Any more members with ideas?I have a 07 and planning a system in it I wanna do two runs of positive right off and where are you guys grounding everything in back? http://www.youtube.com/user/blackoutt334?feature=mhee
MIKE-2U Posted November 16, 2012 Author Report Posted November 16, 2012 Right now i have a positive run and negitive run off front battery. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
