Tarball Posted October 15, 2012 Report Share Posted October 15, 2012 I just installed a Pioneer AVIC-F90BT in a 98/99 S10. I have A LOT of noise with engine off or on with the key in the forward ignition position. With the key in ACC no noise. I'm going to add a solid ground to the deck and also would like to do the Pioneer RCA ground trick. Any advice on grounding the RCAs seeing as they are pigtails? Thanks, CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
