Birdie415 Posted October 18, 2012 Report Posted October 18, 2012 I'm building a box for 2 RE sex 12s. I have the dimensions i want for a total of 4 cu volume. just having a hard time using a box calculator for the port size. the box is 15.25" high, 35" width, 18.5" depth. I want the subs facing up and the port on the front. It will be a single cabinet. I would also like it tuned to 33 hz. Any input is greatly appreciated. Thanks
Joe X Posted October 18, 2012 Report Posted October 18, 2012 Your dims are too tight for 4 cubes net and you are not saying what vehicle or amp you have.
Birdie415 Posted October 18, 2012 Author Report Posted October 18, 2012 The vehicle is a 2000 blazer. The width needs to be 35 max, and the depth at 20 max. The height I can play with. The amp will be a Kenwood kac-9105D 1 Chanel monoblock amp. Just looking for help as I want it to sound good.
Joe X Posted October 18, 2012 Report Posted October 18, 2012 So here is a suggestion subs up/port back: Enclosure Specifications: Fb = 33 Hz Vb = 4 ft^3 External Height = 18.75 in External Width = 35 in External Depth = 18.5 in Port Width = 3 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Top & Bottom = 35 x 18 1/2 Left & Right Sides = 17 x 17 1/4 2x Front = 15 3/4 x 17 1/4 Back = 35 x 17 1/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 15 1/4 x 17 1/4 2 x Extension = 9 7/8 x 17 1/4 Assembly guide (generic dimensions): Let me know any questions.
Birdie415 Posted October 18, 2012 Author Report Posted October 18, 2012 That looks great and just what I'm looking for. thanks ... btw what program did you use if i may ask?
