king-chi1 Posted January 18, 2008 Report Posted January 18, 2008 how do u convert a round port into a slot port.... I got this design for an enclosure that's 16.8cu.ft. net w/ (4) 6" round ports 9" long ........how do change (4) rounds ports into an area/slot port ???? thanks, chi
andym85 Posted January 19, 2008 Report Posted January 19, 2008 well (4)6" round ports has 113.04sq" of port area area = pi*r^2 3.14*3^2=28.26 four ports: 28.26*4=113.04sq" of port area so to convert that into a square port you just need to come up with some measurements to give you around 113sq" for example a port that is 20" x 5.5" gives you 110sq" or a port 20"x5.75" gives you 115sq" of port area...which is pretty close to 113sq" i likes me some audio stuff...
king-chi1 Posted January 19, 2008 Author Report Posted January 19, 2008 well (4)6" round ports has 113.04sq" of port areaarea = pi*r^2 3.14*3^2=28.26 four ports: 28.26*4=113.04sq" of port area so to convert that into a square port you just need to come up with some measurements to give you around 113sq" for example a port that is 20" x 5.5" gives you 110sq" or a port 20"x5.75" gives you 115sq" of port area...which is pretty close to 113sq" 20" x 5.65" =113sq so, is 20" x5.65 the width x height and if so, whats the depth??? is it still 9" deep???? thanks
andym85 Posted January 19, 2008 Report Posted January 19, 2008 the depth is gonna change b/c the square port isnt gonna displace as much air....so basically your enclosure is gonna end up bigger and ur port is gonna need to be shorter... i likes me some audio stuff...
