Noel989 Posted October 22, 2012 Report Share Posted October 22, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Noel989 Posted October 22, 2012 Report Share Posted October 22, 2012 The bit 1 I think has that not sure if that's the name of it Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
KingPepsi Posted October 22, 2012 Author Report Share Posted October 22, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right I plan on running an Audison Bit one which has its own vol control but the issue with that is I lose all of my steering wheel controls. This signature intentionally left blank. Link to comment Share on other sites More sharing options...
Noel989 Posted October 22, 2012 Report Share Posted October 22, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right I plan on running an Audison Bit one which has its own vol control but the issue with that is I lose all of my steering wheel controls. One promblem solve found another lol have you look to see if they have anything for the steering control? But I'd rather loose the steering control than not knowing where I clip Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
KingPepsi Posted October 22, 2012 Author Report Share Posted October 22, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right I plan on running an Audison Bit one which has its own vol control but the issue with that is I lose all of my steering wheel controls. One promblem solve found another lol have you look to see if they have anything for the steering control? But I'd rather loose the steering control than not knowing where I clip SOLUTION! Integrate a DD1 into my dash to monitor distortion hahah. Or an O-Scope. But I think my Tektronix scope is a bit big to fit in the dash. This signature intentionally left blank. Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 22, 2012 Report Share Posted October 22, 2012 That was my suggestion, and what i did. But i ran the RF.2. But, a bit 1 is the bee knees... and does have its own vol knob..... and would solve your immediate issue... good luck SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Noel989 Posted October 22, 2012 Report Share Posted October 22, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right I plan on running an Audison Bit one which has its own vol control but the issue with that is I lose all of my steering wheel controls. One promblem solve found another lol have you look to see if they have anything for the steering control? But I'd rather loose the steering control than not knowing where I clip SOLUTION! Integrate a DD1 into my dash to monitor distortion hahah. Or an O-Scope. But I think my Tektronix scope is a bit big to fit in the dash. Lol If you get the vu-din you can kinda keep track of where your at Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
Kyblack76 Posted October 22, 2012 Report Share Posted October 22, 2012 Great idea... set it with it... and you will have a good idea where your at.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
KingPepsi Posted October 23, 2012 Author Report Share Posted October 23, 2012 Maye you can add a lil bump (so it'll get "stuck") one on the deck surface and the other one on the knob so you can mark the minimum and maximum so it won't spin more that it has to The knob needs to be rotated roughly 15 times to get to max volume. Can you get some like an external source something like when they add iPads but no deck and a volube knob I can't remember what's it called right I plan on running an Audison Bit one which has its own vol control but the issue with that is I lose all of my steering wheel controls. One promblem solve found another lol have you look to see if they have anything for the steering control? But I'd rather loose the steering control than not knowing where I clip SOLUTION! Integrate a DD1 into my dash to monitor distortion hahah. Or an O-Scope. But I think my Tektronix scope is a bit big to fit in the dash. Lol If you get the vu-din you can kinda keep track of where your at That is actually the perfect solution! Thank you so much! I even have a spot where I can nicely integrate the VU Din. Good call man! This signature intentionally left blank. Link to comment Share on other sites More sharing options...
Noel989 Posted October 23, 2012 Report Share Posted October 23, 2012 Make sure to post your progress man I'm sure it'll help others too Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
