BUILD: 2001 GMC Yukon XL
Since I been thinking of going the XXX route...
Worked up some dimensions according to the specs from Craig ( see post #8 )
45w x 24d x 17h with 18" long port and with 56sq in - ended up with a 3.7" port
At these specs the port is tuned for (Fb) 20.993Hz and driver (Fs) is 21Hz in my head it says its too low...
What do you guys think ??
21 hz?? Damn idk I would think, with a proper box... might be musical??
Not sure...just a free bump ttt!!
98' dodge ram
140A alt
Big 3
XS D2700
JVC kd-r310
Rockford T500-1BDCP
2 Sundown E12 Ported 4cubes 35hz
Rockford P400-4
2 Infinity reference 3way 6x9
2 Polk DB 5 1/4
2x layer dynamat all doors
Settled on the deck...
Its going to be a Clarion NZ502
Got all the bells and whistles for daily use and more convenience features than most decks out there in the single Din Segment.
RIght now the RE xxx Component set looks like a pretty good deal to me so I might put 2 sets in the front of truck ( stock location and kick panels ) and settle for a co-axials for the rear.
  • 1 month later...
Hey guys...
Been busy at work and not much went on so far.
Amps were ordered and been in customs for a few weeks now... YAY :/
Replaced the dieing stock battery with a optima yellow top and have a second one waiting to go in once i have enough time to finish the tie down bracket and retaining bracket for the cap ( Stinger 50F ). Hopefully this wednesday or thursday I will have some time to drop in the wiring kit ( Dual 0 Ga runs ) and try and figure out if someone has a analog to digital converter so instead of running 3 sets of RCA's i can run a single SPDIF cable into the 3Sixty and then into the amps.
I will be running a relay for remote turn on however I don't think its gonna be a big issue with the deck supplying the current to turn on 2 amps, but i always liked to play it safe.
That's about it
Interested in seeing how it goes, however you definitely don't need a relay for 2 amps. I've got 2 2000w RMS amps and 560w 4 Channel and use the one remote. I'd love to see the RE Audio XXX's. I had a single 12 a while back and they sound really nice in a good box. Really heavy things though even heavier than my Fi SP4 18.
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
  • Who's Online   0 Members, 0 Anonymous, 1138 Guests (See full list)
