LIMITED SLIP DIFFERENTIAL (LSD) I NEED HELP ASAP
So, building a drift car as a daily driver (no, not gonna be riced out.) BUT i need a LSD, and there is this AD on craigslist, and on this 320i BMW is a Toyota Supra LSD. heres the question, are are LSD's the same size? or do i have to get a specific one? new to this. i wanna know before it gets sold, because it wont be long
Just go get your diff welded. It'll act the same as an LSD.
An LSD and a welded diff are NOT the same thing.
Big 3 with Yellow Top
I didn't say they were the same. I should have said that the welded diff will be suitable for entry level drifting.
1999 Honda Civic- RIP
2003 Acura RSX Type-S
getting your diff welded is called a "Lincoln locker" its most defiantly not made for drifting cars.. your ass end will start to hop around and it will eventually break the welds.. that is a bad idea, just get a real locker
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
No, limited slips are not all the same size.
And I wouldn't recommend welding your diff on a Daily Driver
Source: Parrot Asteroid Smart
Processor: Digital Designs X1
Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400
Front stage: Hertz 165xl + HL 70 + HT28
Rear fill: Hertz 165xl
Subs: 2 SA-12's
3-way active ftw
just save up and get a real locker.. it will be better for you in the end, will make sure you do spin both or none at all every time. a limited slip diff can still spin just 1
  • Who's Online   1 Member, 0 Anonymous, 732 Guests (See full list)
