Right now I have a two Kicker L7 15s with a Crunch 3000 PZI.1 running at 1 ohm. I only have stock electrical (battery and Alternator). My question is, how much better would it be if I added another battery and did the big 3? Would it make a big difference? OR...could I just switch out my stock battery and replace it with a yellow optima instead of just adding another battery? Thanks.
2008 Chevy Impala (undercover cop style)
Setup in the makings
You should always do the big three
More than likely you will add more strain to your electrical system then helping if you add another battery because you have a stock alt. There arent enough excess amps for ur amp probably, let alone another battery to charge so...
Get a ho alternator, and that is the best thing you could do for the system, once you get one then upgrade the stock battery
Get a deep cycle battery for the rear since you are pushing ~1500w (maybe kinetik1400/1800)
In a perfect world ud have the same battery in front as in the rear but alot of people dont follow that
imo
imo
Alright so the best thing I could do right now would be to get a H/O alternator along with the Big three? You really think my amp is pushing 1500 watts?
Correct ;)
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
B)-->
QUOTE(Eric B @ Jan 19 2008, 06:11 PM) 233577[/snapback]
Correct ;)
Was that "correct" also answering that I am only getting 1500 watts too out of my amp (sig). :huh:
well how are they wired, and what vc coil are they
i mearly assummed you had 2 2ohm dvc wired series-parrallel getting 750 each
but do you have them par-par
*edit o so 2 4ohm dvc, damn they handle 1500w a piece?
Not sure what coil but the L7's are wired at 1 ohm. I was just wondering at 1 ohm what watts you think they were getting.
