redrider Posted December 26, 2012 Report Share Posted December 26, 2012 Thanks a lot for the help guys I appreciate it!!! how did the router turn out? good buy? did you end up getting the jasper jig for it? reason i ask is im in the market for a router nothing crazy to help with jobs here and there but dont want to spend a ton of money on one and it sit there....i also like the fact the bluehawk comes with a table for it. audio setup HU: sony Amps: cadence csa5000.1(running at 1 ohm 1200w x 1) Subs: pair of cadence s2w8-s2 Doors: cadence zrs65k's component set Box: customed glassed box tuned @ 35 hz with one 4" port....built by me Underhood: powerbastards.com H/O 200 amp alt, big 3 upgrade(4 awg) and optima red top battery Wiring: SQ audio 0 awg amp kit Cadence Sponsored build http://www.stevemeadedesigns.com/board/topic/133648-96-s10-cadence-audio-build/page__hl__cadence Link to comment Share on other sites More sharing options...
IKnowImLost224 Posted December 27, 2012 Author Report Share Posted December 27, 2012 Thanks a lot for the help guys I appreciate it!!! how did the router turn out? good buy? did you end up getting the jasper jig for it? reason i ask is im in the market for a router nothing crazy to help with jobs here and there but dont want to spend a ton of money on one and it sit there....i also like the fact the bluehawk comes with a table for it. It also comes with a 3 year warranty! But yes I did get the jasper jig and it worked flawlessly! I do feel like the plunge mechanism is a little tough to compress (it takes a lot of force) and it is pretty hard to change out bits when it's mounted to the table. But it does get the job done. I used it to cut the hole but did it wrong by not making multiple smaller cuts and just going all the way through one piece of 3/4 mdf. Hope this was helpful! Link to comment Share on other sites More sharing options...
redrider Posted December 30, 2012 Report Share Posted December 30, 2012 yes it helped... i just picked up this system tonight from lowes for 90 bucks. great deal for sure! curious since i havent bought any bits yet, what brand did you buy? since the jasper jig works i will be buying one for sure. audio setup HU: sony Amps: cadence csa5000.1(running at 1 ohm 1200w x 1) Subs: pair of cadence s2w8-s2 Doors: cadence zrs65k's component set Box: customed glassed box tuned @ 35 hz with one 4" port....built by me Underhood: powerbastards.com H/O 200 amp alt, big 3 upgrade(4 awg) and optima red top battery Wiring: SQ audio 0 awg amp kit Cadence Sponsored build http://www.stevemeadedesigns.com/board/topic/133648-96-s10-cadence-audio-build/page__hl__cadence Link to comment Share on other sites More sharing options...
IKnowImLost224 Posted January 2, 2013 Author Report Share Posted January 2, 2013 yes it helped... i just picked up this system tonight from lowes for 90 bucks. great deal for sure! curious since i havent bought any bits yet, what brand did you buy? since the jasper jig works i will be buying one for sure. Originally I just bought a Skil 3 pack round over set then bought the spiral up cut an flush trim bits from eBay for much cheaper. They work just as good as anything else though Link to comment Share on other sites More sharing options...
