why i can hear the engine through my subs?pls help
what up folks,i need some advise regarding,why i can hear the engine through my subs,it wasn't doing after i change my box to a bigger box,i did a couple of things check the rca,took the rca's off the amp and it stops,so i went out and bought a new pair of rca's,took the new ones plug them on the amp and my deck,not right next to the power line and it was still doing it,then i tried putting my ground in different spots and i also put on the negative side of the battery,and it was still doing it.there isn't really much i can do because i dont have tools to check the rca's if its working right,if there someone out there that had this problem before, i greatly appreciate it if you guys can help.
rockford fosgate r500-1 mono 500 rms
rockford fosgate p3d4-12 600 rms
kenwood 252u head unit
double check ALL your grounds
maybe try grounding the H/U im pretty sure there is a thread on here about it
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Only thin I can think of is run your RCA on the opposite side of the car from all of your other wires and keep you RCA away from the fire wall, also tr adjusting your pre out voltage on your amp and make sure it is within H/U specs
  • Who's Online   0 Members, 0 Anonymous, 1193 Guests (See full list)
