Hi i recently installed a stinger volt meter and i have noticed that sometimes when im driving with the music off the volts stay around 14.2
other times with the same circumstances the volts stay around 13.6
big three has been done in 4 gauge
i have a standard under the hood and a yellow optima in the trunk (100amp alternator)
im wondering if this random difference mean somethings wrong?
i did a 4 gauge ground off the standard battery negative to the chassis
this is the only thing i can think that could maybe do something i dont want
or maybe 4 gauge wire isnt big enough (only pushing 1000 rms tho)
i appreciate any feedback thanks!
**actin bad like a kid at six flags**
you are most li,kely experiencig a hotter temperature when you see your voltage lower. when wires and alternators heat up resistence is higher so you will see a greater voltage drop. as far as how low is too low for votage. try to stay above 12. above your batterys resting voltage is better.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 1881 Guests (See full list)
