SO I played a 60HZ Test tone 3/4 volume & set it to 61.7 Volts @50hz and Bass knob all the way up pushing 3786 @ 1ohm to a fully loaded 18" BTL Daily use. Is this right?I hope it is......I want to know if I did this right HELP PLEASE!!!Cmon Steve Help out a brotha!
if you're going to use the bass knob, then you should set the bass knob as high as your going to turn it, then set your amp gain to the desired voltage read in ac from the speaker outputs @ 60hz
