Alright folks, I'm really jazzed that I get to use this tool. I set all my setting flat on the HU. There would have been a vid of that, but there are several menus on the HU. I'm sure I'm making a mistake somewhere. If I need to provide more info, then I will. Thx
Vid 1
Vid 2
Vid 3
Bass eq on amp is set to 0. Subwoofer level is set to 0 on HU. The HU crossover is set to 80hz. Do I need to change that? Is my HU sub crossover overriding my amp crossover?
Edited by sierra mist
Turn that all the way up. . Have you tried the 1khz to see if it does the same on that track. If you can, use the RCA's to check head unit max volume with the 0db tone. It seems to be something with your head unit. Whats the equipment you are running
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
I haven't tried the 1khz yet. Would I need to do that on the full range amp? My equipment is:
Alpine INE-S920HD
Alpine MRX-M110
Crossfire VR404
Alpline SPS-610S comp set
