Went to a car show on the weekend and met up with Club VE
5 Hours of cleaning for nothing got home and it started pooring rain before i could get it inside ( My luck )
New HID Lights
Back to the build
I had stuffed up massively and the box did not fit with the subwoofers to the back, Also have to remove all the rim around the doors to slide the box in. Doesnt matter when the box is it i just put it back on and it sits tight
Had to do major surgery on the box that i used massive amout of gue, This wasnt fun at all......
Only testing the box, Had both subs in and sounded awesome. Much louder and deaper now its ported
Started wraping some parts
Raining all weekend so i filled the garage up with saw dust sanding
Box is carpeted every CM of this box. Looks so much better then the last ( will get better pitures later of it )
So you may be thinking how do i get such a massive box in ?
I remove both seats, Remove trims around seat belts
Sorry for all the poor lighting it has been raining every weekend and has all been done inside
Without anything installed
First installed the base
Followed by the box its self
Installed all trims and seats and BAM
How does it sit in the car? ( more photo's to come! )
had my door pannels off the tweets sounded so much better not being muffled by the door so it hurt to do this but worth it
I also added some foam between the mid bass woofer and the spacer and also between the spacer and door. Just future proofing for rattles
Also got bored and wrapped my console
Started to stock pile my cleaning gear working out the crap and the good stuff
Changed the stock exhaust
To a SS mid section
Its a direct bolt up. it looked a little bigger but the main reason i went SS over aftermarket or SV6 is im not a massive fan of the alloytec note.
Especially on a auto..
Hows does a SS cat back sound? Sounds good. Nice deep note, No drone, bit louder and im happy with it
SS had 2 hot dogs over 2 mufflers and no flex pipe ( outlined with red in the picture )
Couple of new snaps
Played with the coilovers then jacked it back up
Let somone out of the Kitchen and wrecked a rim
VN's do single peggers out the front of my house. Aidan says no
The final happy snaps when i found Mother brand wax before screwing the front bumper and 2 more rims
Couple of weeks later wax doing a fine job
Won a Audio comp. Will now be installing 0 Gauge
Old VS New
Show at Eastern Creek With some ClubVE members
Seen a ClubVE member selling this intake at a price i couldnt say no to
Decided to move my catch can to a better spot
Why do you have this car if you are a P Plater?
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
Holy crap that is a lot of pics...
The green commodore (2 posts previous to this, fourth pic from the bottom on the right) is that car from ACT because those rims n colour look familiar...
Nice work on the centre console trimming and box, it looks good! If you're ever down ACT way I would very much like to have a look.
Never mind I see you noted before it was only a 3.6L, I thought it was a V8 for some reason.
2012 Subaru BRZ:
