1385291_10151803755179902_1958211828_n_z
1383367_10151803755229902_1589547039_n_z
Decided to flush mount the subwoofers to give it a bit more strength and less chance of the woofers getting hit
1375206_10151803754959902_1463611059_n_z
1379749_10151803755094902_940623316_n_zp
996618_10151803755454902_165350765_n_zps
1380422_10151803755384902_1572897923_n_z
1393638_10151803755054902_1376535483_n_z
I used T-Nuts this time to hold the subwoofers in as my last screws kept coming loose and with T-Nuts i can remove the Subwoofers as many times as i want without stuffing thr wood
1377058_10151803755539902_1813112665_n_z
1384054_10151803755604902_2018643244_n_z
The ports are bigger each box then what i had for both subwoofers before
1381490_10151803755504902_1399609625_n_z
Before wrapping in carpet and installing
1381306_10151803755669902_1002292699_n_z
1383911_10151803755849902_819182313_n_zp
Also Decided to not use the Subwoofer Protective ring as i found it to rattle and also gives it a different look
1383332_10151803755909902_1335325842_n_z
Battery is in and working awesome, Engine kicks over easier and have no more light dimming issues even with the system up, Headlights on and footwell lights. Wired the subwoofers at 1Ohm this time and what a difference the box, Battery and wiring change has made is huge! Just what i was looking for with the lower tuning and it now gets much louder
Done a bit more tuning to the subwoofers on the weekend. Brought this over a year ago and never used it
Ute looks like it has a lift kit in this photo due to the angle of the driveway ahah
Plasti dip started to come off my front badge so i sprayed it a Saturn Black
Stock brakes are crap as we all know. Was looking at brembo's but dont want to invest so much into this car as i want a V8
Brought a complete set of brakes of a mate with a SSV. Only going to use the bigger calipers and do slotted rotors and upgraded pads.
At this stage ill paint them Black or Blue..
Due to turning up the Bass amp i have started to blow fuses due to the extra amp load. Pull the boxes out and put it some new bigger fuses
So i have been working away at the GTS rims sanding my figers off and finally getting some results
Was testing with Grey, Matt black, Gloss black and Gloss white. White just stood out to me so for now im spraying them white while i get my current set on my car sprayed Gloss Black or Charcoal Grey
1474726_10151885309439902_2106955442_n_z
1420055_10151885309434902_278421861_n_zp
1421330_10151885309449902_2039909588_n_z
1470519_10151885309429902_1819581482_n_z
1476870_10151885309029902_1865828400_n_z
Took the intake off to fix the Maff due to the screw holes being threaded, Fixed that up and noticed the Air hammer pipe had cracked to wielded that up
999630_10151931379049902_2090834732_n_zp
1471879_10151931379114902_1316741814_n_z
Had a new tyre installed on my Spare set of GTS rims and sprayed them White for something different
1459331_10151931379399902_1169915340_n_z
Installed the new SSV lower and fog light grills
1472985_10151931379149902_1703986318_n_z
1463496_10151931379179902_841644359_n_zp
Played with my IQ for the first time. Had the IQ fully unlocked to enable DVD player and reverse camera. Installed some RCA cables myself and all works perfect ( more pics to come )
524762_10151931383419902_14775886_n_zpsb
1476126_10151931383304902_2103931412_n_z
Also got some speakers at a bargin price so will install them on the back wall temporary unless i like the sound of them ill keep them and wont trade for Rockfords
564646_10151931382969902_170856858_n_zps
Also had the battery terminal come loose cause a hot joint and nearly start a fire, Wire burnt so hot all the solder made a puddle on the top of the battery!
Removed the subwoofer box, Made new power wires and installed a second ground wire and tightened the terminals so that wont happen again.. No more dimming of headlights or power issues fingers crossed
1479241_10151931383084902_977110724_n_zp
I had one of these stickers ever since the day i picked the ute up, 4 different colours now i think white matches it perfect and stands out more
1460284_10151931385024902_706686158_n_zp
1471789_10151931385259902_876797773_n_zp
Gave the ute a bloody good clean and wax heres how the new wheels look! What do you think? im considering keeping white over black GTS rims now.
In progress of swapping out for some Brand new coilovers for a bit more low
1497746_10151931382899902_1646305117_n_z
1474539_10151931383509902_1822420795_n_z
To cut a long story short i wasnt happy with my Coilover setup after jumping in my mates GTS that just put K-Sport Coilovers in. It drove so much better then mine
What have i done............ Brand new K-Sport to be going in!
616322E4-88FC-4C61-B6DC-17D8C6DF8FAF_zps
57C86FFC-7670-4C59-9E3A-1714C7A81856_zps
96015A4D-9D1C-4D6E-8E30-7F72B5C01D04_zps
Some time ago some some nice people broke my windscreen. Photos is only some of the lines, it was worse then this pic, Both side had cracks from top to bottom
09DFBCFF-FEBC-48C6-B118-1C7CB6DA5316_zps
Had it replaced under insurance had to take a pic after it was done next to one of the bosses cars to show him a real car :boxing:
28B4CFB5-AFF1-4047-9E01-7E743F43D944_zps
I Finished work early Friday and was way to excited to install my new coilovers so a few drinks later had the rear bolted in just before the sun went down
5BCEEE80-B8C2-4575-8D13-7EA3DF922C0A_zps
ED283BF4-1520-40FB-9F60-3E96EFD04DA4_zps
5D7094DD-9D4D-4B7C-9B44-3C0FB2FF9F54_zps
Got up early the next morning to tackel the front and here is where it went all down hill...
First we dropped the truts and little silver balls dropped everywhere my fears had come true, Bearings are screwed on both sides. No signs of noise or anything what was werid
BB4E20D6-B0A6-449D-9D89-A87111B272F9_zps
AE2C00BD-4A8A-4AE3-AD2A-E825DAD22255_zps
Lucky my local Autobarn was open and had one set left
D2A25FCF-E632-43C0-A894-729B7CFA6DB2_zps
7072F368-3F2C-408F-BFF3-50AFCE9ED46F_zps
Had everything in and working a treat. Took it for a spin handled awesome. Went over it double checking bolts and found the strut top bolt was loose. Snapped a allen key and was unable to undo or tighten up the trut top
2722A77E-A737-4547-834B-0CC405DE5887_zps
3B42CC92-E086-4AE5-BCA7-053885277B4D_zps
Not only did i spend 4 hours trying to drill the allen key out the allen key was stripped and turned sideways. Under this allen key is the adjuster, i was screwed!
55472105-0C62-4B0B-864E-57A032425060_zps
5A285ED7-83CD-40CC-B0B4-EB7A18808F5D_zps
Couldnt drill the allen key out so got the shits and attacked it with a angle grinder so i could atleast undo the strut. Next day after work drive 2 hours to pick up a replacment shock
48D8AE4D-9447-4A3E-8371-E65EA3850AD2_zps
That night installed the coilover again but this time didnt snap the allen key. I was very over looking at the car at this stage so didnt care for height
0765BE19-EF88-4992-9BF7-30732BB967CD_zps
Few days later the love come back and played with the height. As you can see having it this low isnt drivable so set them to a normal height and will adjust them when the springs settle
0AF7AA66-6322-40AB-A362-F767CB823A28_zps
6C8DF7FD-3BE0-4193-BB17-78F90A2D5841_zps
CBAE949D-3AE8-48A7-99E1-D2ADF80C2E44_zps
You said someone else broke your windshield? Who?!?!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
My Rockford speakers in my doors had stopped working just out of warrantly ( My luck )
I replaced them with some Soundstream speakers and are real happy. Made some propper door spacers this time
Was time to rip the tray out to adjust the dampening. Spoke the owner of K-Sports, He told me the correct settings.
Didn't want to cut the tray but i ended up having to. Springs are now settled i will drop the front a but lower this week ready for a wheel aligment on Friday morning
I got my hands on some brand new clubsport seats chucked one in
Heres the good stuff a little eye candy! I searched the land far and wide for these bloody wheels and finaly got my hands on some!
1596470_10151998510964902_512884403_o_zp
New plans to rebuild the system but bigger this time for the final install
  • 6 months later...
I barely only use this website. not going to post most of the stuff i do on here as i use another site. Will keep it more sound system only for this site
Wanted to sort out my intake as the screws had threaded and bracket snapped. Sound a O ring cleaning in the middle of the intake manifold. Replaced them and Plastic wielded the screw holes.
Brought a HSV radiator cover. Cleaned the engine up. Still unsure if ill use the engine over or not
Sound system is out again for a full rebuild should be the best one yet. Battery is now relocated
Heres the line a drew not to go over.. Not a bad measuring job :)
3C06F178-1FAA-4053-A82E-5F5D3B8EA50D_zps
7C2B932C-223E-4ED0-A6F3-DB83FF6583F2_zps
8DFD1BF1-1973-4384-B7B9-EED4B410AA05_zps
5EC55163-5184-4A15-8BA1-A98C19693CA4_zps
588D19DD-58E7-44A3-80DF-7555B3CE19A7_zps
A9CF6734-D247-4351-AD91-63367454DC79_zps
B82BEA6B-22AD-4314-AE02-508134B85BA9_zps
B6C4D5DB-E97A-4B6E-A950-AF5A53617965_zps
7FD3C404-8CA8-4A24-96BF-DDF80404DCDC_zps
58D4C427-5D41-49EB-949B-EC4100CD5FED_zps
8A5CD667-7A9D-4831-97A7-05A8E6F249ED_zps
5D015CAC-8611-4935-A9A1-F322339EFED0_zps
EDCA8220-9AEB-4549-B63A-A1A5F0E30507_zps
7042AF6E-BFBD-4F5C-8A08-A1742795C483_zps
T-Nuts. The only thing i use to screw my Woofers in now
74026E3E-1A48-4964-9CB3-5F2B1B1F7FCE_zps
50DAA130-FE92-482A-84FC-CDB630653463_zps
6F325997-F600-40DC-93E7-1DADDBF69174_zps
Look at all the room are activities now!
7A2FF6FD-43B3-431B-BF6E-4E7D3FE9FBA0_zps
