well I just got done taking it for a test drive at 2.6 ohms and.............. It clips the same :(
I think I'm gonna sell the TR2000 and get (4-6) 1600 watt Power Acoustik Gothic Series OV2's. They were my next favorite amp, and I know they measure thier stuff in peak, but they are BAD ASS for the money! It's like 800 watts RMS for around $150 shipped. And if I try hard enough, I could probably get around $800-$900 for the TR200. (retail=$1500)
What kind of electrical upgrades do you have?
4- COMP VR 15's
2- Tang Band 8's
2- Selenium 6"
2- Selenium Tweets
2- SAX 100.4's
1- SAZ 3000D
1- KQ9
1- KX3
Hopefully it doesn't sound too horrible. lol
Well, I have 6 car batteries, and 50+ farads of capacitor on a stock alt. I haven't done the big 3 upgrade because I was waiting on some thicker wire. Do you think that would keep the amp from clipping?? If so then I'm gonna do the big 3 in 4 awg.
816-591-6592
www.kcrimshop.com
its prob been asked?
but how do you have your amp set? if its set properly it should not be cliping, or is it turning off, or going into protect mode?...
and instead of running 6 amps why not just get 2 pa3000ds and strap them at 2ohm since your at 2.6 or what not and go from there that should be plenty of power and much much eaiser to connect, and would only cost 500 shipped... vs the 650+ with 6 amps
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
I would have to agree on that.
Youtube.com/J Hutch22
x2 on the 2 amps as I'm positive they won't tax your electrical as much as the 6 would, also another good point about the gains being set properly.
4- COMP VR 15's
2- Tang Band 8's
2- Selenium 6"
2- Selenium Tweets
2- SAX 100.4's
1- SAZ 3000D
1- KQ9
1- KX3
The TXX-AP15RD subs are Dual 4ohm coils. Not 2.
So each sub has a possibility of 8 or 2 ohm.
Really, Is that the only configuration? That means that the 2.66 final ohm load is out the window.
4- COMP VR 15's
2- Tang Band 8's
2- Selenium 6"
2- Selenium Tweets
2- SAX 100.4's
1- SAZ 3000D
1- KQ9
1- KX3
**hangs head** man, you guys are all right. I should have known about the dual 4 ohm vc's. Well, I normally pick up on shit REALLY fast. Taking that into consideration, I'm going to wire it up differently. If you have any suggestions please throw them out there. I'll post up a diagram of how I wired it in a little bit
816-591-6592
www.kcrimshop.com
2.66 For 3 subs with their coils in series.
Paralleled for a final load of 1.3ohm.
This is his best out, but is his amp 1 ohm stable. I don't know much about your amp but, it might do fine with impedance rise.
4- COMP VR 15's
2- Tang Band 8's
2- Selenium 6"
2- Selenium Tweets
2- SAX 100.4's
1- SAZ 3000D
1- KQ9
1- KX3
