HELP!?!?! explorer guy's/ car guy's
so when it started to get cold out here (iowa) like 1 month ago my truck would be dead in the morning. only when its real cold! and only like 1 time a week. got my batt/alt tested and they are both good. 14.4 v with lights,heat,system, all the stuff on. so i did the test light thing were u take off the negative and put the test light on.... so i find that i have something surging(test light was going real bright to real dim) .... i can hear a click click like every 30 sec from under my dash so i go under i find a box with relay's in it. i start to pull them intell the click stops and the test light goes real dim light it should be. the relay thing was for my windows so when i took it out my windows do not work. i got a new relay and put it in and the test light stayed dim and there was no click click so i thought i was good. well it has been like 2 weeks now and this morning i went out to start my truck and it was dead!!!!!! so i do the test light again and same thing as before! and this time my truck would not even jump intell i took the relay out. so i think i have a short or something not sure. someone have this problem before ???? or know what i should do to fix it? truck is a 96 explorer xlt 4.0 v6 -4dr 2wd
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
No input on this?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
you're not holding a fuse in that picture. its a relay. relays make the click click noise.
i could not remember what it was called lol
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Bump
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Bump
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
fuck my truck is now dead with no relay in!!!!!!!!!!!!!!!!!!!
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
find the short. trace all the wires from under neath that relay panel as best as you can
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   1 Member, 0 Anonymous, 879 Guests (See full list)
