2012 SEMA Kinetik Battery Booth Featuring 1951 Mercury "Reprise" Bio Kustomz JL Audio Show Car
http://www.kinetikaudio.com
The Kinetik HC Series Car Audio Power Cells are the perfect power solution for car audio professionals and enthusiasts alike. With 10 different models ranging from 600 watts all the way the way up to 3800 watts of clean and pure power output Kinetik has a model that will work for your system. Need more than 3800 watts of power, no problem just add more Kinetik Power Cells to create the ultimate power solution. If you just want to stop your lights from dimming when that deep bass line hits or if you want to join the ranks of the pros, Kinetik has the power your system needs.
http://www.rodauthority.com/news/sema-2012-jerry-hortons-bio-kustumz-built-1951-merc/
Jerry Horton's full-custom 1951 Merc. If that name sounds familiar you might
be a rock fan as Jerry Horton is the guitar player for band -- Papa Roach. Jerry began
this build with a "custom" he bought a few years back with the hopes to turn it into
the lead-sled that he had always envisioned.
Entrusting Max Fish and the team over at Bio
Kustumz with the build, they soon learned that
this wasn't a "lead-sled" at all. As they dug
deeper they realized it was much more of a fiberglass
and bondo sled in need for some serious repairs.
So Max did what he does best and began to cut, weld,
and shape entirely new panels and lines, turning this
once poorly treated Merc into the beautiful custom that you see here.
Stripped down, Reprise started to come together
with custom metal work from front to back.
The hard work began to recreate the Merc to Horton's
exact specifications, and all though Jerry Horton is
no self-proclaimed car builder, he knew exactly what
he wanted and how he wanted it to look from the start.
To give the car the look Jerry was after, Bio Kustomz
hand formed each body panel and rechopped the roof.
The front clip, which was found to be fiberglass,
was replaced with hand-built steel panels flowing
the new lines from front to rear. Bio even custom-built
the car's quarter panels to eliminate some of the bulk and give
the Merc more sharp, yet subtle lines. Max couldn't stop there,
with everything needing to match perfectly, Bio decided that
no wheel currently on the market was exactly what Jerry was after,
so they machined completely one-off wheels to finish off the Mercury in style.
After all of the pain-staking metal and body work
was completed, Reprise was sprayed with a custom-mix
of House of Kolor paint, giving the car an almost green/orange
chameleon-esque finish.
Powered By Al & Eds AutoSound Marina Del Rey & DRC Media LLC
