Guest [email protected] Posted November 17, 2012 Report Posted November 17, 2012 I listen all the time to r&b, rap, hip hop and some time rock. I like SPL more than SQ (i like it when it hits hard) so what tuning frequency do you recommend? I prefer slot port over the round port. I have limited trunk space:- Width is 36 inch Height is 15 inch Depth is 28 inch (I need some trunk space try to play more with the depth) The MDF we have here in Saudi Arabia is 18 mm(0.7 inch) or 24 mm(0.944 inch) I need box design for the following setup:- 1-two pioneer champion pro 12” ts-w3002d4 3500w 1000rms each http://www.pioneerelectronics.com/PUSA/Car/Subwoofers/Champion+Series+PRO/TS-W3002D2|D4 2- Hifonics Brutus BRZ2400.1D http://www.maxxsonics.net/manuals/hifonics/pdfs/HifonicsBrutusBRZAmplifierManual.pdf Q1: I bought 220amp alternator for my car but the positive battery terminal is fused (120 amp) should I change the fuse with bigger one ? how many amp the fuse should be? Q2: am running these subs at 1 ohm is it safe or not? thank you
Guest [email protected] Posted November 17, 2012 Report Posted November 17, 2012 i prefer one port box its easier show me your magic bros
Guest Posted November 21, 2012 Report Posted November 21, 2012 you're expecting a free box design, that should normally cost money. and you want it fast? LOL
Joe X Posted November 21, 2012 Report Posted November 21, 2012 Ok so here is a suggestion for a box, specified in metric units, 18mm wood: Enclosure Specifications: Fb = 33.4 Hz Vb = 3 ft^3 External Height = 37 cm External Width = 82 cm External Depth = 51 cm Port Width = 8 cm Cut Sheet List: * All Dimensions in Centimeters. * Wood Thickness is 1.8 for all Parts. External Enclosure Parts: 2x Front = 37 x 33.4 2x Front Internal = 33.4 x 33.4 Back = 82 x 33.4 Left & Right Sides: 47.4 x 33.4 Top & Bottom = 82 x 51 Shared Port Internal Assembly Parts: 2 x Front to Back = 43.4 x 33.4 2 x Extension = 14 x 33.4 Assembly guide (generic dimensions):
Guest [email protected] Posted November 21, 2012 Report Posted November 21, 2012 Ok so here is a suggestion for a box, specified in metric units, 18mm wood: Enclosure Specifications: Fb = 33.4 Hz Vb = 3 ft^3 External Height = 37 cm External Width = 82 cm External Depth = 51 cm Port Width = 8 cm Cut Sheet List: * All Dimensions in Centimeters. * Wood Thickness is 1.8 for all Parts. External Enclosure Parts: 2x Front = 36.1 x 33.4 2x Front Internal = 32.5 x 33.4 Back = 82 x 33.4 Left & Right Sides: 47.4 x 33.4 Top & Bottom = 82 x 51 Shared Port Internal Assembly Parts: 2 x Front to Back = 43.4 x 33.4 2 x Extension = 14 x 33.4 Assembly guide (generic dimensions): thanks bro so much what about the rectangular thing in the middle of the port? and plates in back corners?
Guest [email protected] Posted November 21, 2012 Report Posted November 21, 2012 you're expecting a free box design, that should normally cost money. and you want it fast? LOL thanks anyway at least answer my questions
Joe X Posted November 21, 2012 Report Posted November 21, 2012 thanks bro so much what about the rectangular thing in the middle of the port? and plates in back corners? Those are 45s, if you can't do slanted cuts on wood then you can just not do them, like this: If you have any other questions let me know.
Guest [email protected] Posted November 25, 2012 Report Posted November 25, 2012 thanks bro so much what about the rectangular thing in the middle of the port? and plates in back corners? Those are 45s, if you can't do slanted cuts on wood then you can just not do them, like this: If you have any other questions let me know. thank you so much can you send the google sketch for both boxes please
