Refinishing 2006 Mustang GT's mirrors+front splitter
My buddy asked me to refinish his 2006 Mustang GT's front splitter (bumper lip) and mirrors...so here we go, started with the mirrors...
Ugly seam that I'll be sanding off...
Getting started on that seam...
Prepped with 400-grit...
Primed...
Going to let dry, flip them around, hit them lightly with some sand paper (probably 600-grit) and then do another light coat of primer...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
As long as you don't burn through the primer while sanding, there shouldn't be a need to reprime. If the surface is good and smooth sand it with 600, shoot your color then clear. Just trying to save you from doing extra work :) Post pics when youre done :good:
My F-150 Build (So Far)
2 DC L3 10's
Kenwood KDC-X794
(4) Selenium ST200 (Highs)
(2) RE X8 (Mids)
Sundown Sub/Mid/High Amps
Shuriken Batteries
Knu Wiring
My Feedback Thread
Thanks, yea I'll try not to go back down to plastic through the primer and just paint it then clear. Planning on getting them as close to the factory gloss black look like his mustang as possible. These and the splitter should look so much better on the car afterwards.
Team Tupperware
Hit them with an initial black coating, with a few imperfection that I see (you can see most of them in the pics) I may be lightly sanding again and repainting before moving to clearcoat.
More later tonight, most likely.
Team Tupperware
A light follow-up coat ;)
More when it happens...
Team Tupperware
Rigged up a piece of mdf from the shop to prop these up to clear the whole mirror in one go
Team Tupperware
Thanks, man :)
Team Tupperware
Dat clear...
Team Tupperware
  • Who's Online   1 Member, 0 Anonymous, 3672 Guests (See full list)
