RCA output voltage while streaming Bluetooth audio? DD-1 helps find a problem!
Wicks
So my DD-1 helped uncover an issue with my Kenwood DNX-6990HD head-unit. :good:
I was installing my new DC5K and wanted to check the output of my Kenwood again to make sure I wasn't feeding the amp a dirty signal.
Well, I was getting very weird readings with the DD-1, no signal but distortion at all levels and other flaky readings.
This was using the RCA's directly into the DD-1.
So I ripped the Kenwood out of my dash and did some troubleshooting.
Turns out that the "pico fuse" on my RCA grounds/outside conductors is blown.
I have no connection between the RCA outside conductors and the HU chassis.
The DD-1 worked great using the supplied cable with the ground lead attached to the HU chassis.
Fearing that something else may be faulty, I started to measure the RCA output with various sources.
Using the SMD DD-1 Test Disc with a 0dB track, I was able to measure about 4.7Vrms from the RCA's which is what I'd expect.
Then I switched to my iPhone4 and connected it to the Kenwood through Bluetooth which I often use since my iPhone has a noisy signal from the 30-pin connector. With the volume on the iPhone max'd, I could only measure about 1.5Vrms from the RCA's.
(All settings flat and volume max'd at 35, no clipping)
So...has anybody measured their RCA output from their HU while using a Bluetooth device?
I'm curious if this is normal or whether my Kenwood is indeed messed up.
I have an email into Kenwood but wanted to ask around here as well.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Were is your is bass level and the HU?
I also have a kenwood and when I did mine I tried it at +10 and it clipped right away so I just went back and left it at 0 even though I was good at +4
Also mine didn't distort like yours at 35 but it sounded like shit when I went pass 31-32 so I retuned it to 30 being my max volume
Bass was flat. I can raise it to +2 before it distorts but I leave it flat.
Sub level also can go to +2 before it distorts.
With flat settings, the volume can go to the max of 35 with no clipping or distortion.
That's what I used to measure the RCA output.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
kenwoods have pico fuses? you learn something new every day
News to me too.... :trippy:
It must have one 'cuz the outside conductor of my RCA's has no ground connection at all. Resistance between the RCA outer conductor and the chassis is in the mega-ohm range.
Therefore I'm concluding that it has a "pico fuse" and its blown.
We'll see what Kenwood comes back with, but I can't possibly imagine this HU is set up to return the RCA signal through the chassis ground....
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
  • Who's Online   0 Members, 0 Anonymous, 875 Guests (See full list)
