08 vw rabbit door speakers
Nikedunks
When installing door speakers in a 2008 vw rabbit can I just replace the speakers and use the factory crossovers or do I need to use new ones.
assuming that it has crossovers maybe, depending on ohm load. would i no, why? well each speaker isnt the same and might need different crossover and octave slopes. like say one speaker sounds good from 80-4khz but the other sounds good from 150-4khz. well you dont want to put the second speaker on the crossover for the first speaker or else it will be getting to low of a freq damaging the speaker and sounding horrible.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1120 Guests (See full list)
