pittross Posted December 5, 2012 Author Report Share Posted December 5, 2012 ttt Link to comment Share on other sites More sharing options...
Joe X Posted December 5, 2012 Report Share Posted December 5, 2012 Well since you bumped it up here is a suggestion, 1 cubic feet + port as Kicker suggests: Enclosure Specifications: Fb = 36.5 Hz Vb = 1 ft^3 External Height = 12.25 in External Width = 24 in External Depth = 11 in Port Width = 1 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 21 3/4 x 10 3/4 Back = 24 x 10 3/4 Left & Right Sides: Side 1 = 9 1/2 x 10 3/4 Side 2 = 10 1/4 x 10 3/4 Top & Bottom = 24 x 11 L Port Internal Assembly Parts: Front to Back = 8 x 10 3/4 Extension = 18 x 10 3/4 Assembly guide: Link to comment Share on other sites More sharing options...
pittross Posted December 6, 2012 Author Report Share Posted December 6, 2012 Well since you bumped it up here is a suggestion, 1 cubic feet + port as Kicker suggests: Enclosure Specifications: Fb = 36.5 Hz Vb = 1 ft^3 External Height = 12.25 in External Width = 24 in External Depth = 11 in Port Width = 1 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 21 3/4 x 10 3/4 Back = 24 x 10 3/4 Left & Right Sides: Side 1 = 9 1/2 x 10 3/4 Side 2 = 10 1/4 x 10 3/4 Top & Bottom = 24 x 11 L Port Internal Assembly Parts: Front to Back = 8 x 10 3/4 Extension = 18 x 10 3/4 Assembly guide: thank you Link to comment Share on other sites More sharing options...
Joe X Posted December 7, 2012 Report Share Posted December 7, 2012 No problem pittross. If your amp features a subsonic filter engage it to 30Hz at least. Link to comment Share on other sites More sharing options...
pittross Posted December 7, 2012 Author Report Share Posted December 7, 2012 No problem pittross. If your amp features a subsonic filter engage it to 30Hz at least. ok hope i can start 2mm Link to comment Share on other sites More sharing options...
