jl008 Posted November 29, 2012 Report Posted November 29, 2012 i have a couple questions and i bet you guys can help me out. I just received my new batcap 4000 from fed ex. I checked its voltage and it rests at 12.76 volts. Now should it be charged before i install it? And second i have a optima yellow top up front so when i run the power wire to the batcap in the trunk, what size fuse should be used in that run? they will run off a 220 amp alt, with the big 3 already done. Thanks in advance for any advice!!! set up Alpine 9851, Sundown sax 100.4d, Digital Designs M3A, Incriminator audio components X 2, HCCA Tweeters, 2xDD 3512sc dual .7 coils , H.O 220 amp alt, Optima yellow top under hood, batcap 4000 in the back, Big 3, and all 0 gauge runs. For now but it's never finished!!!
DubNDodge Posted November 29, 2012 Report Posted November 29, 2012 What is your wire rated for? That's what you would want to fuse at or below. Personally, I would put a fuse 18" from each battery '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
jl008 Posted November 29, 2012 Author Report Posted November 29, 2012 Im not sure of the rating on the wire its 0 gauge flex wire. I looked at it and didn't see a rating. set up Alpine 9851, Sundown sax 100.4d, Digital Designs M3A, Incriminator audio components X 2, HCCA Tweeters, 2xDD 3512sc dual .7 coils , H.O 220 amp alt, Optima yellow top under hood, batcap 4000 in the back, Big 3, and all 0 gauge runs. For now but it's never finished!!!
DubNDodge Posted November 29, 2012 Report Posted November 29, 2012 What brand is it? I'll go see if I can find a rating on it. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
jl008 Posted November 29, 2012 Author Report Posted November 29, 2012 Its audio pipe primary wire. This is wire i have running my amp. I can get different wire if i need to. set up Alpine 9851, Sundown sax 100.4d, Digital Designs M3A, Incriminator audio components X 2, HCCA Tweeters, 2xDD 3512sc dual .7 coils , H.O 220 amp alt, Optima yellow top under hood, batcap 4000 in the back, Big 3, and all 0 gauge runs. For now but it's never finished!!!
DubNDodge Posted November 29, 2012 Report Posted November 29, 2012 Curious, what size fuse do you have on the run going back to the amplifier, or is none of this installed yet? I can't find a single rating on that wire, not on their site or anywhere it is listed '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
jl008 Posted November 29, 2012 Author Report Posted November 29, 2012 No i haven't installed it yet. Im just getting all the stuff now. The only reason i was thinkin about using that wire is because i already have one run already from the the battery to the amp. Its not set in stone to even use it. Thank you for looking into it for me. set up Alpine 9851, Sundown sax 100.4d, Digital Designs M3A, Incriminator audio components X 2, HCCA Tweeters, 2xDD 3512sc dual .7 coils , H.O 220 amp alt, Optima yellow top under hood, batcap 4000 in the back, Big 3, and all 0 gauge runs. For now but it's never finished!!!
jl008 Posted November 29, 2012 Author Report Posted November 29, 2012 Im sorry i do have a 150 amp fuse on my amp. set up Alpine 9851, Sundown sax 100.4d, Digital Designs M3A, Incriminator audio components X 2, HCCA Tweeters, 2xDD 3512sc dual .7 coils , H.O 220 amp alt, Optima yellow top under hood, batcap 4000 in the back, Big 3, and all 0 gauge runs. For now but it's never finished!!!
