What to add for LOUD AND CLEAR 300C
ThreehundredC
lol no. not cutting the whole wire apart just. making the 16 feet into two 8foot. sections and crimping to a connector or twisting the ends and stick it in the amp.. but since it was one wire. it has one fuse@ the end..would i need to add another fuse for the second run or could i somehow use the one fuse for the two runs to the same amp.. i already have a amp kit on order. so this will be temporary just cant wait two more weeks to get this thing up n running
You just confused me on that one, the only thing that you wire in series or parallel are the coils of the subs, but i probably would suggest using a class d amp if you are running subs
well ups says itll be here late tommarow i hope so..
BACKto speakers. has anyone use the american bass VFL 8s. found em local for the same as onlinr so i might get them
CAN ANYONE HELP ME WITH WTH TO PLUG THIS TO. chrysler 300 boston acustic amp bypass.. has two harness and other end wire
dont bump your thread after an hour.
its made specifically for the boston acoustics amp in your car. so its obviously clear that you use it on the harnesses that go into the boston acoustics amp.
there are likely instructions. i see them in the picture.
edit: by the way, a 4 channel is fucking useless for subwoofers. use monoblocks.
  • Who's Online   0 Members, 0 Anonymous, 1681 Guests (See full list)
