Ok I'm lost on this right now and need a little help,
I got 2 12" DVC subs, and there wired into the amp in 2 channel. Both subs are wired the same yet when you start to turn it up about half way the one subs will still hit normal while the other one looks like it sucks in.
They kind of look like there going in opposite directions during certain frequencies, One will hit while the other one goes down a little. If anyone could help me I'd appreciate it :]
Also one more question, there DVC 2 ohm subs wired for 4 ohms in two channel, i want to know if there is any possible way I could wire them so there bridged at 4 ohms rather then 2.
got the wires reversed and if that dont work try them one at a time on the each side to see if someone hasnt repaired the amp and screwed up on the inside
well i tried switching the positive and negative wires that go into the amp and that did not work at all! All that did was make the sub produce no bass what so ever and just heard vocals out of it.
Maybe its just the one channel and something is wrong with it? I'll have to give that a look?
Also is there anyway at all to make them 4 ohms when bridged? I doubt there is but I'm open to any suggestions
Take a 9 volt battery and put your positive speaker lead to the positive on the battery and negative speaker lead to the negative on the battery. If the subs move in opposite directions, they're out of phase. To fix it, pull the sub that moved backwards and switch around the positive and negative speaker wires.
Also, you can't wire two 2 ohm dvc subs to 4 ohms.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
