Loud & Low 8th Gen Civic - Time to say good bye to her.
Ok well it's still fucked up but I'll see what I can do to post things up. Here we go.
So I left off last time with pulling the fiberglass shell out of the car, and it was next time to clean it up and get things ready to build on it. It came out pretty easily, thanks to the foil I put down!
Then I peeled the foil and tape off. Most of it anyway, cause some of the tape lifted up and the resin got under it. But that's what happens sometimes.
Next I just trimmed off the excess mat that was hanging off. I'll trim it with the grinder later to get a nice square edge.
NOW FOR SOME SEXY TIME!
Had to make a panel for the amps to sit on. This isn't the amp panel, just a template for them so I can get some looking and setting done. Then I'll transfer them to 1/2" birch.
Putting in work I see? Looks good so far Scott. The trunk mold came out killer!
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
So here it is. Finally revealing the configuration. Well some of it anyyay :peepwall: The best is still to come, but I'll save that for later.
I put the shell and the panels in for some test fitting and some adjustments etc.
Wasn't really happy with that and the angle so I took it out and did some adjustments outside of the car so I wouldn't have to lean over the trunk. At this point I was starting to think the glass pan wasn't going to work.
That was all I got to on Friday night. I had things going on so I had to pack it up and do some more on saturday.
However, the more I thought about it the more I was tempted to toss the pan. Sux cause it's a lot of material and a lot of work, but that's how things go! Try it and if it doesn't work you learn from it.
So I got up Saturday morning, and had a couple things to do in the morning but I went out with the amps and did some testing, no pics unfortunately, and I was much happier without the pan. It's tight in there anyway, and the pan takes up some of that precious space so the pan just simply had to go. Chalk it up as a good experience. So I moved on.
Started feeling around on the deadener, cause it seemed be lumpy and loose. Well, it was. I pulled it all. The black original Dynomat. The rest was good, the foil stuff, but the black mat was just garbage. No big deal, clean slate now. That wasn't why the pan didn't work btw. Just to clear it up before you guys ask.
So the next order of business was to create a flat floor base. The bottom of the well is just too uneven to get a good base and it just made it too difficult to deal with getting the amps straight etc. So, back out comes the cardboard that I use so much. Helps after you've moved too, you have an abundance of it at your disposal!
Worked it a little bit
and finished up a template
Time to transfer that to a piece of 1/4" ply.
Test fit it.
Sits a little high so I marked it for trimming.
Got it trimmed up and it fits perfectly. Sits on the floor flat. Dropped it about a half inch almost.
Moar!!!!
Calm your tits, I'm working on it. This is a painstaking process......THANKS PHOTOFUCKET!! Nothing is in order so I'm having to compare order on my phone to search for the right pic on PB. Sucks ass! There's about 88 pics I'm posting.
Thanks. Didn't work out right, but it is what it is.
Ok back to posting pics. Please hang on to comments until I'm done, so I don't miss any. Thanks!
So I had a piece of 1/2" birch that I was hanging onto that got all messed up cause it was left out under my leaky tarp at my old house. But most of it is still good so I didn't want to just trash it. So this is the best time to start using it.
You can see how it's weathered. But thankfully it's all on one end and one side. SO about 70% of it is still usable.
And I have just the use for it! Time to transfer the template to it!
Got all that cut out, now it's time to clean it up!
I didn't have any 2 sided foam tape, gotta get some, so I had to improvise. Took some scrap pieces, and used them for spacers, and then screwed the half inch, to the pieces, to the template.
This allowed me also to use these points as feet and stops so the template sandwich wouldn't move. Not the normal way to do it, but hey, works for me.
Add in one router with one flush trim bit,
and you get a matched up template and final piece.
So while that was good, there was an issue, that I already knew about. I used 1/4" for my template, so if I just put this in there, then it will raise the floor up an 1/8". SO to keep that down, I got a little creative. I actually didn't do the best job on this, but i'm trying not to think about that. LOL you all know how I am!
Anyway, back to the router. I flipped the template over again, and used the 45* bit to angle the edges on the bottom. This will allow it to sit down and clear the edges of the wheel well. This was probably too big of a bit to use, but it's what i had on me. My other one is in my trim router box, and I was too lazy to go get it. LOL
before
after
You can see there that I had it a little low. It cut right at the edge of the top part, maybe a little into it, but we'll see if it will work, and if not, I'll make another one.
The three steps, Cardboard, to 1/4" ply, to 1/2" ply.
Fit test
Not bad. It's a little loose at the curved side, but the back side is perfect. Sits nice and snug in there. This wheel well is not symmetrical so you, and myself, have to remember that. It's going to really show up in a bit.
So now that that's done, it was time to get those panels made into the 1/2" birch.
then there were two!
Drum roll...............................................................................................
TEST FIT!!!!!
These pics you can really see how non symmetrical the well is. See there's about a 1.5-2" difference on the left side.
So I had to make sure the amps didn't extend up above the floor level. I didn't have anything long enough to go from bump to bump on the trunk of the car, not sure if that makes sense or not, but there are bump that raise up on the trunk floor. The floor base for the trunk will sit on those so I have to stay below that level. So I took the two 1/4" templates and put them together with a square to get a straight line and used that for my guide. Here is the height check!
Right side, within an 1/8"
Left side within an 1/8"
That was what I did on Saturday! Good progress! I took the step backwards, and tuned it into 2 steps forwards. I was very happy on Saturday night!
just caught up to your build log scoot... I've been look at that HU you have... do you like it?
I haven't installed it yet. I need to either get a new dash kit, or make a temp one for the cubby under the dash. SO I haven't used it yet. But I hear great things about it.
Ok more pics coming!
  • Who's Online   0 Members, 0 Anonymous, 21213 Guests (See full list)
