Jgrizz Posted December 5, 2012 Report Posted December 5, 2012 So I'm going to be running 4 sundown audio sa-8v.2 going to be doing a build log or whatever they are called, soon. Till then I need some answers. I am new to electrical updates because running one of these 8's doesn't require upgrades unless your pushing it with an NS-1 1. I am going to run an extra battery a kinetic HC 1800, will this suffice with 2.5k watts? 2. I drive a 2002 Jeep Grand Cherokee and wanted to just add another alternator dedicated to the system itself, i figure this will be cheaper than buying an HO alt because I can get a stock one from a junkyard. My question is does anyone know if I can mount a second one in my jeep? Think thats it for now, thank you!
Mlcantin Posted December 6, 2012 Report Posted December 6, 2012 You can mount many alternator for your grand cherokee you will just a bracket made if you are going to use two alts or more. And I would go with a d3400 bro for the battery
Noel989 Posted December 6, 2012 Report Posted December 6, 2012 I think 1 h/o alt will be better and cheaper than getting 2 oem Alts and the bracket. look how much you going tto spend in a bracket and the second alt vs a single h/o alt The only thing I see better with the dual alt setup would be if you plan to upgrade to bigger Alts later on Build Log - http://www.stevemead...-cruiser-el-pt/
Mlcantin Posted December 6, 2012 Report Posted December 6, 2012 I think 1 h/o alt will be better and cheaper than getting 2 oem Alts and the bracket. look how much you going tto spend in a bracket and the second alt vs a single h/o alt The only thing I see better with the dual alt setup would be if you plan to upgrade to bigger Alts later on No you're wrong lol
Miguels Posted December 6, 2012 Report Posted December 6, 2012 having 2 oem alts is a good idea if you run the 2 together to supply the amps to the battery bank.. there is no point on having a dedicated oem alt for the bank when it will do just the same as running 1 oem alt.. put the 2 together wired to the front battery then run a wire to the back battery. depending on alts that will = 240a alt my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted December 6, 2012 Report Posted December 6, 2012 you also need to account on how much the bracket will cost plus the belt and your time.. Noelito is right.. its easier to run 1 H/O alt then messing with a bracket getting a new belt and a alt to = the same power not saying cheaper but a lot easier and no trouble my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Noel989 Posted December 6, 2012 Report Posted December 6, 2012 I think 1 h/o alt will be better and cheaper than getting 2 oem Alts and the bracket. look how much you going tto spend in a bracket and the second alt vs a single h/o alt The only thing I see better with the dual alt setup would be if you plan to upgrade to bigger Alts later on No you're wrong lol I never said I was correct thats what I think 1 h/o is better than 2 oem Alts and it's less work Build Log - http://www.stevemead...-cruiser-el-pt/
Mlcantin Posted December 7, 2012 Report Posted December 7, 2012 I think 1 h/o alt will be better and cheaper than getting 2 oem Alts and the bracket. look how much you going tto spend in a bracket and the second alt vs a single h/o alt The only thing I see better with the dual alt setup would be if you plan to upgrade to bigger Alts later on No you're wrong lol I never said I was correct thats what I think 1 h/o is better than 2 oem Alts and it's less work I lol so I was joking. Appears to be a fair statement to me
