Wiseracing2 Posted December 5, 2012 Report Share Posted December 5, 2012 I have found that I dont have enough port area, i have the right volume, but not enough area...So in my Torres tuning calculator i found that i could add a second 4 in port at 16 inches in length and have .27 cu ft of volume when and 15 square inches of port area at 42hz. My sub recommends .07 cu ft of port volume and with my 1 4in port at 9 inches in length, it gives me .07 cu ft but only 7 square inches of port area which ive read isnt enough at 39hz. So whats better? Lower port area or higher port volume? Whats a negative to, to much port volume? Thanks! My sub is a Rockford Fosgate T1D212 -1994 Dodge Dakota -Lifted -Murdered out -Pro comp beadlock rims and General Grabber At2 tires -Rockford T1D212 -Rockford 750.1 at 910w RMS -Focal Solid 4 at 75x4 -Rockford T1 6.5 up front -Rockford Punch 5x7 in rear -Sony BT38U headunit with bluetooth,etc -Rockford 4 Gauge -Singer 250 amp alt! -Race accessory HIDS _______________________________________________ -Soon to come- D3400 Kicker 2500.1 Fi BL 12[/font] Link to comment Share on other sites More sharing options...
john253a Posted December 5, 2012 Report Share Posted December 5, 2012 post the screen shot your max dimensions. amp and coil config Link to comment Share on other sites More sharing options...
Wiseracing2 Posted December 5, 2012 Author Report Share Posted December 5, 2012 post the screen shot your max dimensions. amp and coil config http://s897.beta.photobucket.com/user/2harrison/media/PortareaVsvolume.png.html The width is 20 and height is 18.. sorry it got cut off! and the amp is a Rockford Fosgate 750.1 wired at 1 ohm -1994 Dodge Dakota -Lifted -Murdered out -Pro comp beadlock rims and General Grabber At2 tires -Rockford T1D212 -Rockford 750.1 at 910w RMS -Focal Solid 4 at 75x4 -Rockford T1 6.5 up front -Rockford Punch 5x7 in rear -Sony BT38U headunit with bluetooth,etc -Rockford 4 Gauge -Singer 250 amp alt! -Race accessory HIDS _______________________________________________ -Soon to come- D3400 Kicker 2500.1 Fi BL 12[/font] Link to comment Share on other sites More sharing options...
Wiseracing2 Posted December 5, 2012 Author Report Share Posted December 5, 2012 Bump, need help here -1994 Dodge Dakota -Lifted -Murdered out -Pro comp beadlock rims and General Grabber At2 tires -Rockford T1D212 -Rockford 750.1 at 910w RMS -Focal Solid 4 at 75x4 -Rockford T1 6.5 up front -Rockford Punch 5x7 in rear -Sony BT38U headunit with bluetooth,etc -Rockford 4 Gauge -Singer 250 amp alt! -Race accessory HIDS _______________________________________________ -Soon to come- D3400 Kicker 2500.1 Fi BL 12[/font] Link to comment Share on other sites More sharing options...
