could you please tell me what you used on spraying you box in the tahoe, and where i could get it, what color is that you got, please cause iam about to cover my box with something and i would like to spray it like what you got. thanks
I believe he used rustoleum spray paint that was textured, he got it from home depot. I saw it at home depot the other day going for about 10 bucks a can
Too Much Stuff to list .
he used spray on bedliner. vortex i believe
DC.jpgDC POWER
Btw the other stuff is fleckstone (sp) but im pretty sure he used vortex (SP) on it
DC.jpgDC POWER
im pretty sure its the flexstone stuff...I am using it on a box i am building for a friend and i recommend if you want it to be real black then lay down a black primer before you put the textured stuff on.
2005 Nissan Altima 2.5 S
HU: AVIC-D2
Fronts: ARC Audio KAR KS6006 Components
AA Poly Mids/ CDT CW-19 Tweets in kicks
Front Amp: Profile AP400x2
Rear Fill: None
Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps)
AMP: RF t10001bd x2 (1400-1500 @ 1 ohm)
Wire: Welding Supply/Lighting Audio 1/0 Power/Ground
Zero Noise 2.0zn RCA (x2)
260 Amp Iraggi Alternator
im pretty sure he used the bedliner on the hoopty, the civic and chickens towers... but he used the fleck stone stuff from home depot on his box for the tahoe
whats everything i need to do that, flexstone, i went to the website, but which one is it, and black primer?, textured? please explain, little confusion, just got out of the hospital, still trippin off of morphine
well here's my box, its pretty damn big, and its goin in the back of a 2000 nissan xterra, and its a tight fit, literally, so i need something thin, i've sanded it down some with a belt sander, but still need something thin,
here's the pic
id start off by using something like sanding sealer as a first coat or two because mdf is like a big sponge for paint.... after that do a coat or two of black and then do 2-3 coats of the fleck stone. for a box that size i would buy 3 cans.
