FamilyB4Others 2005 Acura TSX build - JL Audio, Focal, knukonceptz, Eclipse, kinetik, Optima -VIDEO update
This is my install, nothing crazy but though I'd share it with you SMD guys/girls. Hopefully I'll have the funds to do something over the top on my next build.
Car is a 2005 Acura TSX
Equipment list
2 x 12 Eclipse Titanium subs
1 JL Audio 1000/1v2
1 JL Audio 300/2
1 Focal K2P 6.5 components
1 Alpine CDA-9886
1 Kinetik 1400 battery
1 Optima yellow top battery
approx.. 20 Ft. 1/0 ga KnuKonceptz CCA power wire
approx.. 20 Ft. 1/0 ga KnuKonceptz CCA ground wire
approx.. 20 Ft. 4 ga Knukonceptz CCA power wire
approx.. 20 Ft. 4 ga Knukonceptz CCA ground wire
etc.
Let me know what you guys think. I'm open to improvements and suggestions. Thanks for looking.
Heres a picture of the car so for now. I'll upload more in a bit.
Alpine CDA-9886
JL Audio 1000/v2, 300/2v2, the 300/4v2 pictured (not being used in this build)
Optima battery
KnuKonceptz CCA wires
Cross Flow fans for the amp
START of the Big 3
Running the Big 3
Solder the wire
Terminals on
Heat shrink ends
Old/stock/OEM wire from big 3
New ground for tranny
New ground for engine block
New alternator wire to battery
New battery ground with old next to it. First fuse holder mounted on left side of battery for Alternator wire. Second fuse holder mounted on inter-fender for second battery in trunk
DONE! With the Big 3
Box Build time
Clamped
Corner shot of box
50% finish
Bracing time
Front cut out 2 x 12 plus 8inch port hole in middle
Tight fit between port hole, sub hole and the bracing dowel
The double baffle cut out
Test fit
All wall and port braced
Brace is wood glued and screw to the box plus kitty hair fiberglass for stronger support.
Almost there
Carpet
Done with the box.
Your car is super clean and that box turned out awesome. I've always liked these Acuras. Keep it up, looking forward to more!!!
Thank you, heres more update pictures...
Amp Rack time
Getting measurements with carboard
Test fit
Carpet time
Amp and crossover with cross flow fans installed on the rack
Done with the amp rack
Looks nice and clean so far. I like matching amps
2004 Escalade Ext
Pioneer avh8400
Kicker ix500.4
Kicker ix1000.1
Kicker hyperflex 0+4 awg
Sundown X-15
Sundown Sa-6.5c x2
KnuKonceptz 4 channel Rca
Rockford Fosgate 2 channel Rca
SkyHighCarAudio 14awg speaker wire
Build Log
  • Who's Online   2 Members, 0 Anonymous, 1737 Guests (See full list)
