JBL GTO 14001, help.
evo90
Bass boost, just put electrical tape over that knob.
Hp/subsonic depends on ported or sealed box. Generally most subs / boxes will unload below 20something hz. Need more info on that.
Low pass should be between 60 and 80 hz
Input gain needs to be matched by the output voltage from your head unit going Into the amp. Best way is to find someone with a DD1 and ask nicely.its worth it...
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Bass boost- why?
Subwoofer box are jbl p1220 br ported (Dimension: 58cm x 35cm / 25cm x 38cm) no more information abot bot in google.
Subwoofer are jbl p 1224- 12", 400 rms, 4 ohm, voice coil 3.0", sensitivity 94db, Fr 23-450 Hz.
But this HP is 10 Hz-100Hz, and some where is 20, but how i can know 100% where is that 20 Hz?
Right.
But some as Low pass is 32Hz-320 Hz, where is that 60 or 80 Hz., i dont know 100 %.
Right. DD1 are good thing.
Thanks again!!
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
