Hi
i recentely bought a VW Golf mk4 that had a two way air ride already installed.
So far i have had to change the relay and also the switches seemed dead when i tested them, So am in the process of changing those out.
380 viar compressor
easy street gauges
1/2" valves
front universal uvair bags
rear firestone bags
Here are some pics of the setup:
Having a few problems with it so hopefully new switches will sort it.
Also on the relay, the wire for the compressor has melted. Im not sure why.
Is there anywere i can get some red illuminated switches?
Also whats a good digital management system i can get?
Everywhere online recommends this pdf as the one to read. But that link is dead so just wondering if anybody had a copy they could upload or send me? Would be much appreciated
http://www.easystree...nuals/27741.pdf
Also is there a diy on how to wire switches to the valves?
I am going to use three switches, one for front, one for rear and one for both at same time
Fitted all new switches and have them working now
Also have a switch in centre for all up ,all down
Need some ideas now for a show boot build.
Cant think how to do it as there's only one tank and one compressor.
So not sure of a layout
Check out this place for some installs. Most of the best Bagged VW's are using bagyard
http://www.bagyardairride.co.uk/index.shtml
or
these guys for tips, installs, and stuff. http://www.bagriders.com/modlab/
Good luck with the rest. and lets see more pics.
If it's worth building, it's worth over building.
Thanks il take a look.
I will get better pictures tomorrow.
Im thinking of getting two digital gauges
One for tank and for both front and rear bag pressure.
I have filled the tank up to 150psi and all bags to 50psi,
I will update tomorrow on what the pressure is as there seems to be a small leak somewhere
Also do i need a water trap?
I also want to put my AA Havoc in the boot but only concern is i wont have easy access then to spare wheel which is where the air setup is.
Would i need to access the air setup reguarly?
I could possibly fit water trap and run it to the side of boot.
Is it ok to run the water trap around a meter out from in between the tank and compressor?
I want to put my AA Havoc in but this will take up the whole boot space.
Meaning i would have to remove the sub every time i need access to water trap
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
