jazz5000 Posted December 22, 2012 Author Report Posted December 22, 2012 looks good. I will get ordering then. The leak is more of a issue now aswell. Im hoping its not going to be a big problem
NYC54 Posted December 22, 2012 Report Posted December 22, 2012 Fill up the tank and spray soap and water all over your lines you can see where the leak is coming from , also make sure your fittings have enough teflon tape
jazz5000 Posted December 22, 2012 Author Report Posted December 22, 2012 Ok thanks il give it a try. If theres a leak in the air line would i need to replace the whole line?
NYC54 Posted December 23, 2012 Report Posted December 23, 2012 If the leak is coming out where it connects to the fitting , I would just cut the tip straight and try reconnecting them ...if its coming from the middle of the line or something I would change the whole thing , if your system is new I doubt it would be from the middle it's most likely leaking from one of the fittings
jazz5000 Posted January 12, 2013 Author Report Posted January 12, 2013 Picture of front bags Testing remote for wireless air control New wiring for switches New switch holder How it looks in the car Wrapped in carbon fiber. Plan is to retrim it in suede to match the headliner Headliner: This is how it used to sit: But now its back on stock wheels whilst i look for something better. Maybe some BBS wheels What do you think guys? Also have my AA Havoc in temporarily. Im going to make a false floor and then build a much bigger enclosure for the sub,
jazz5000 Posted January 12, 2013 Author Report Posted January 12, 2013 This is how mine is setup What water trap is this? As im from the UK alot of parts are harder to source. My whole kit was imported from USA aswell. Thanks
jazz5000 Posted January 14, 2013 Author Report Posted January 14, 2013 Whats the best way of running the airlines out of the car? Should i use grommets or is there a better way?
