Need help!! Headlights, taillight, and dash lights flickering constantly???
Just noticed on my way to work the headlights and dash light were just randomly flickering. Also did it ( even more noticeable ) while shifting it from drive to park, actually whoever you used the shifter at all, used the power window, turned foglights on etc. . The battery voltage when running kinda bounces from 14-15 volts and 13-14 when at a stop.
I'm just about to install an aftermarket radio and amplifier so the last thing I want is electrical issues. Has anyone heard of this issue before?? Thanks
Car is a 2006 Grand Prix gt. s/c series 3
Look at the simple things first, check battery connection if it is loose, good contact or corrosion , positive and negative, also ground terminal.
Will do. Gonna check the grounds as soon as I can. I did notice tho the entire engine bay including the negative terminal is spotless but the positive terminal has a huge chunk of corrosion on it
Remove, clean, reinstall and check.
Just mix baking soda and water correct?
Will and grease work? Like a lithium grease.
Yes, also, vaseline can work too.
  • Who's Online   0 Members, 0 Anonymous, 7805 Guests (See full list)
