noob needs help wiring
so im 16 just got into this audio bs got my first pair of subs 2 kicker 10 in comp vr in a sealed box and a RF p2002 200w amp for 90$ im getting a a 300w power supply and receiver later on tonight but can you guys just check if i have everything wired up right so far or where the wires are suppose to go on the amp also i have 2 rcv home audio speakers and one infinity speaker should i wire those into the amp or just strait to the reciever
can someone give me a wiriring diagram until i figure out how to post pics
you know you're supposed to hold the camera still before and after hitting the capture button, right? :D
power Specifications - Full Range Channels RMS Power @ 4 ohms 50 watts x 2 channels RMS Power @ 2 ohms 100 watts x 2 channels RMS Power @ 1 ohm Not Stable Bridged RMS Power 200 watts x 1 channels Peak Power Output 200 watts Amplifier Specifications Number of Channels 2 Total RMS Power Output 200 watts Minimum Impedance Unbridged 2 ohms Minimum Impedance Bridged 4 ohms THD at Rated RMS Power 0.05% Speaker Level Inputs No Preamp Outputs 1 pair Built-in Crossover Low-pass (LP)
High-pass (HP) High-Pass Crossover Frequency 40 - 400 Hz Low-Pass Crossover Frequency 40 - 400 Hz Signal-to-Noise Ratio 80 dB Bass Boost 0 - 18 dB
Fan Cooled
No Fuse Rating 30A x 1
If you want help, make sure your information and questions are clear.
well what information do i put am completely new to this audio stuff
