ok to run 4ga. wire?
i have (2) runs of 1/0 to the back to three batteries and then to dist. block / bus bars.. i want to run 4ga. wire to each amp. off the buss bars to 4 amps one pos. and one neg.total of 8 wires (kicker brand) the amps are (2) zxs1500.1 and (2) zxs1000.1, the total length of each wire will be under 3ft.do you think this will have a bottle neck effect...each amp has an estimated 80 amp draw per amp.so you are talking 80 amps through 4g. wire for 3ft.do you think this is ok?
on a similar note , but not answering your question. no matter how big of power wire you run, wouldnt the terminals at the end of the wire be the bottleneck?or even the the fuses?
no i dont believe the terminals at the end of my wire have the "bottle neck effect" as i use the crimp and solder method and ensure full contact of the ring terminal to the connecting surface area. as far as the fuses go i dont believe that is an issue either my real question is the run from the buss bars to the amp. 4 ga. of 3ft.
I think you'd be OK with such short runs.. but why not just finish it with 0 ga. ?
Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi.
Audio: Two 10" Alpine Type R's ( 1000rms models )
Hifonics BRZ 2400.1D @ .5 ohm
Two Kinetic 1400 batteries ( soon to have XS power under hood )
Tsunami 1/0 Awg wire throughout truck.
Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine.
Exterior: 17"Dick cepek rims with 33" Toyo MT tires
Bushwacker fender flares
Magnaflow true duel exhaust
LED tail lights with Projector headlights
Plasti-dip fun coming soon!
  • Who's Online   0 Members, 0 Anonymous, 787 Guests (See full list)
