Cox Posted December 31, 2012 Report Share Posted December 31, 2012 This is for a friend's two Orion Cobalt 10s And I'm not sure exactly if I have the port length right so if you guys could check the box cutout list too that would be nice. Also the circles represent the outside of the subs Cutout list top plate-27x17 bottom plate-27x17 left plate-16.25x12.5 right plate-15.5x12.5 back plate-27x12.5 front plate-23.75x12.5 port 1- 13x12.5 port 2 - 6.75x12.5 Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt Link to comment Share on other sites More sharing options...
Cox Posted December 31, 2012 Author Report Share Posted December 31, 2012 Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt Link to comment Share on other sites More sharing options...
Joe X Posted December 31, 2012 Report Share Posted December 31, 2012 Here is a cutsheet for the above, didn't look at the design itself: External Height = 14 in External Width = 27 in External Depth = 17 in Port Width = 2 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 27 x 14 Left & Right Sides = 15 1/2 x 12 1/2 Top & Bottom = 27 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 13 x 12 1/2 Extension = 5 x 12 1/2 Link to comment Share on other sites More sharing options...
Cox Posted December 31, 2012 Author Report Share Posted December 31, 2012 Here is a cutsheet for the above, didn't look at the design itself: External Height = 14 in External Width = 24 in External Depth = 17 in Port Width = 2 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 24 x 14 Left & Right Sides = 15 1/2 x 12 1/2 Top & Bottom = 24 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 13 x 12 1/2 Extension = 5 x 12 1/2 Thanks joe Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt Link to comment Share on other sites More sharing options...
Jessica Posted December 31, 2012 Report Share Posted December 31, 2012 Here is a cutsheet for the above, didn't look at the design itself: External Height = 14 in External Width = 24 in External Depth = 17 in Port Width = 2 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 24 x 14 Left & Right Sides = 15 1/2 x 12 1/2 Top & Bottom = 24 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 13 x 12 1/2 Extension = 5 x 12 1/2 What the hell? 24" width for front plate and back plate and the box width is 27" wide. Obvious you didn't look at the design Joe. lol Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2012 Report Share Posted December 31, 2012 LOL strangeduck. x2 everything in the design checks out, actually. did your friend prefer to tune that high? or is it because of his music preference, etc? Link to comment Share on other sites More sharing options...
Cox Posted December 31, 2012 Author Report Share Posted December 31, 2012 Here is a cutsheet for the above, didn't look at the design itself: External Height = 14 in External Width = 24 in External Depth = 17 in Port Width = 2 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 24 x 14 Left & Right Sides = 15 1/2 x 12 1/2 Top & Bottom = 24 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 13 x 12 1/2 Extension = 5 x 12 1/2 What the hell? 24" width for front plate and back plate and the box width is 27" wide. Obvious you didn't look at the design Joe. lol It's so I don't have to cut a hole in the front piece. Look at the google sketch up. That's with my dimensions so obviously that would work. Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt Link to comment Share on other sites More sharing options...
Jessica Posted December 31, 2012 Report Share Posted December 31, 2012 O.P. you left out the "3" in the common walls box. That makes your box 2.3 net cuft. You might want to tweak it a bit to get back down to 2cuft Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Joe X Posted December 31, 2012 Report Share Posted December 31, 2012 Obvious you didn't look at the design Joe. lol Just mistyped BUT the port parts sizes are not affected unless the depth is not ok. Link to comment Share on other sites More sharing options...
Jessica Posted December 31, 2012 Report Share Posted December 31, 2012 Here is a cutsheet for the above, didn't look at the design itself: External Height = 14 in External Width = 24 in External Depth = 17 in Port Width = 2 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 24 x 14 Left & Right Sides = 15 1/2 x 12 1/2 Top & Bottom = 24 x 15 1/2 L Port Internal Assembly Parts: Front to Back = 13 x 12 1/2 Extension = 5 x 12 1/2 What the hell? 24" width for front plate and back plate and the box width is 27" wide. Obvious you didn't look at the design Joe. lol It's so I don't have to cut a hole in the front piece. Look at the google sketch up. That's with my dimensions so obviously that would work..... No, joes dims wont work, Torres gives you cut sheets you need, just make the front baffle the (box width - .75 - port width). Then you don't have to cut a hole in it. edit spelling Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
